View Full Version : UMI Performance New Product- Pro Tour Style Rear Sway bar for the 1978-1988 GM G-Body
UMI Performance
09-03-2012, 07:25 AM
Adjustable Pro Tour Style Rear Sway Bar for the 1978-1988 GM G-Body
P/N: #3044
Price: $399.99
UMI Performance, Inc. is pleased to announce the availability of our newly designed Pro Tour style rear sway bar for 1978-1988 GM G-body applications. This 1” dia hollow sway bar is axle tube mounted using our tried and true 2245 serrated tooth mounting clamps, poly bushings and heavy duty u-bolts. Three position adjustability delivers street, road race/auto-x and light drag race performance all from the same bar. Adjustable length race style rod ends allow a perfect fit as well as preload capability for drag racing use. The P/N 3044 sway bar has been designed to accommodate the factory rear housing, GN 8.5, 12-bolt, Ford 9” and Moser M9 while still offering great ground clearance and a clean look. These bars are available with tough red or black powder coat and are designed and manufactured with pride in Philipsburg, PA – USA.
Website Link (http://www.umiperformance.com/catalog/index.php?main_page=product_info&cPath=8_66&products_id=722)
https://static1.pt-content.com/images/pt/2012/09/3044a_LRG-1.jpg
Windy City Chevelle
09-03-2012, 08:14 AM
You guys never responded to my last post I guess we little guys need to have a big shop behind our builds to get any type of brake even a 20% not free stuff like these big builds get
UMI Performance
09-03-2012, 08:19 AM
Hello Rafiq, Sorry I didn't get an e-mail that you replied back in the for sale thread, I will take a look at it. Since it is Labor Day weekend no one is working so it is just me catching up a few things.
Honestly we usually don't do any sponsorships, big or small shops or purchases we try to treat all customers the same.
Have a good weekend,
Ryan
Mkelcy
09-03-2012, 08:28 AM
Talk about the "entitlement" mentality! SMH
Windy City Chevelle
09-03-2012, 09:29 AM
I PM you Ryan
67gtonut
09-03-2012, 11:23 AM
How is the progress on this bar going for A-Bodies?
UMI Tech
09-03-2012, 06:08 PM
Hey Troy. We have that bar coming up soon. We've been driving our LeMans a lot so that's next on our list.
chevelletiger
09-03-2012, 07:32 PM
Hellwig makes a heat treated,3 way adjustable already just paint it red!
67gtonut
09-04-2012, 03:18 PM
Yeah..... i know. But Ramey has treated me well, so I want to be loyal to him.....
Being in the auto business myself, I try to do to others what I would want done to me......
exwestracer
09-05-2012, 04:38 AM
And you didn't even complain that you don't get a big discount...
SLO_Z28
09-05-2012, 04:56 AM
Just wanted to add that preload is good for road racing too, you can get your weights where you want them with adjustable sway bar end links.
UMI Performance
09-05-2012, 05:21 AM
Thanks for the replies everyone, we appreciate the feedback.
We understand this isn't a new item to the market and companies already offer it. Hellwig makes excellent items and they are great people, you can't go wrong with their set up.
One thing different we did with this bar was made sure it fit the long list of aftermarket rear ends on the market. This bar will clear the OEM 7.5, 8.5GN, 12-bolts, 9", M9, S60 and other fabricated rear ends with out issues and with out spacing the bar below the rear end. Many of the bars on the market today are designed to the clear the 7.5 only and some companies sell spacers to lower the car to clear other rear ends, this is a bolt on and go for all rear ends. The pre-load adjustment on this bar is also on car adjustable and doesn't require you to unbolt the end links like other set ups.
Thanks again for looking,
Ryan
Tony_SS
09-05-2012, 07:48 AM
Any reason that it is hollow instead of solid? Is there a benefit to either?
UMI Tech
09-05-2012, 08:29 AM
Hey Tony.
Most of a sway bar's action comes from the outside diameter. Using hollow tubing in the case of this bar saves weight and cost without sacrificing much sway bar rate. As we go up in size and bend complexity, the ability to bend a bar properly shifts to solid and the price flip-flops to solid being less expensive.
In the case of a rear bar like a drag anti-roll bar, we heat treat 1.250" diameter solid because that particular application can use the huge rates and needs the additional strength.
ramey
