View Full Version : ridetech+( umi or hotchkis suspension parts)
lineberrcasey
09-02-2012, 05:19 PM
which should i use for which parts upper+lower trailing arms, sway bars, and pan hard bar
Yelcamino
09-02-2012, 05:33 PM
I highly recommend Ridetech for your project! We have complete suspension (http://www.ridetech.com/store/musclecars/?subcats=Y&features_hash=V277.V328)packages for your Impala and you have the choice of air ride or coilovers using some of the highest quality shocks in the industry.
lineberrcasey
09-02-2012, 05:46 PM
thanks for the response i was going to use the strong arms and cool ride for sure, i would love to go to you all for everything but im on a big budget that's the only reason i was asking
lineberrcasey
09-02-2012, 05:48 PM
does the air-ride stay where its set even when the car is off or do you have to start it and let the bags reinflate
zbugger
09-02-2012, 07:17 PM
The bags should stay where they're at when you shut it off. If it's not holding pressure, there's something wrong. But they also sell coil over setups, so you don't have to worry about any air lines.
UMI Performance
09-03-2012, 06:37 AM
If you are looking for the nice stock style (But not stock) items the UMI items are an excellent items.
Our items are built to replace the factory items and be direct bolt on's. Our upper control arms, lower control arms and panhard bars are all direct bolt on's of the factory items and work with new or existing shocks and springs. It all depends on what you are looking to achieve from the car and what your budget allows.
If I can help any please ask. Thanks!
Ryan
lineberrcasey
09-03-2012, 10:55 AM
Ryan how much stronger are the boxed trailing arms compared to stock thanks guys
Windy City Chevelle
09-03-2012, 10:59 AM
Ryan is right I have UMI rear/front all over Nothing else with QA1 coilovers as recommended by them love their stuff
lineberrcasey
09-03-2012, 11:11 AM
ive looked at the rear sway bar but are the front ones solid or big and hollow
Yelcamino
09-03-2012, 02:15 PM
The bags should stay at whatever air pressure you put them at. If not, there is a leak somewhere in the system.
If the air ride system is not within your budget, you can use the Strong Arms with our coilovers - which are among the best in the industry. They are nitrogen charged monotube shocks with one-piece impact forged bodies. The NA Series have rebound and compression damping optimized for ride quality. The next step up is our SA Series that have adjustable rebound damping so you can fine tune the ride/handling to your liking. At the top of the list is our TA Series with adjustable rebound damping and adjustable high/low speed compression damping. To determine the best coil spring rate for the type of driving you intend to do, you can use our Spring Rate Calculator (http://www.ridetech.com/tech/spring-rate-calculator/). After you provide the requested info, the calculator will give you three suggestions for sping rate - Cruiser/Daily Driver, Performance Driving, and Racing.
UMI Tech
09-03-2012, 06:14 PM
Hey Casey. Our boxed trailing arms are many times stronger than factory. This is a vague answer on purpose ("many times stronger" isn't so legit in the engineering world) since there really is no industry standard for strength measurement. Let's just say you can put as much tire and engine as you want on a UMI bar car and it's all good. 40 year old arms get sketchy with rust, big tires and big power.
Let us know if we can help.
-- Ramey
lineberrcasey
09-03-2012, 08:13 PM
well you just might have me sold i love the fact that your parts are cheaper why pay more for a part of equal quality i say as soon as i get some more $$$(just spent 1200 on dart iron eagle heads plus a little hand porting) im giving you guys and ridetech my business
lineberrcasey
09-03-2012, 08:16 PM
and thanks for the info Herb im still learning this stuff i just turned 18 in June haha
