UMI Performance
08-31-2012, 09:13 AM
Shock and Spring Lowering Kit with Double Adjustable shocks for the 1964-1972 A-Body and 1978-1988 G-Body
Price: $1,099.99
UMI's lowering package consists of four Viking double adjustable shocks, a hybrid front coil over spring system and either 1 or 2 inch lowering Hotchkis rear springs. With moderately increased spring rates for improved handling, this kit allows you to adjust your cars altitude and attitude for maximum performance and a cool appearance. The hybrid front coil system features 0-3" front drop and is easy to adjust and lock in place. The 1 or 2 inch rear lowering allows you to knock the factory height down a bit or go the extra inch for the Pro-Tour look. Double adjustable Viking shocks feature 19 compression and 19 rebound settings. These independently adjustable settings allow you to change from street to strip to corner carving handling simply by turning the knobs. No tools required.
0-3" lowering range up front, 1 or 2 inch choice for the rear
Lower ride height improves handling by lowering center of gravity
Lower ride height improves handling by placing the upper a-arm in a more favorable angle
Viking features Premium quality Made In USA springs, shot peened and coated for durability
Easy front height adjustment with optional Torrington bearings and wrench
Shocks hand built in Lakeville, Minnesota
Double adjustable features 19 independent compression and rebound settings (for a total of 361 possible combinations)
Tune for street, strip or corner carving at the turn of a knob - no tools required
Baseline shock settings - 6C,8R all around street, 10C,12R all around corner carving, 6C,2R front and 6C,6R rear strip
Bolt in kit, no welding required. And best of all, no spring compressor required up front
https://static1.pt-content.com/images/pt/2012/08/AB4250a_LRG-1.jpg
Website Links:
1964-1966 Shock/Spring Lowering Kit (http://www.umiperformance.com/catalog/index.php?main_page=product_info&cPath=1_318&products_id=706)
1967 Shock/Spring Lowering Kit (http://www.umiperformance.com/catalog/index.php?main_page=product_info&cPath=1_318&products_id=708)
1968-1972 Shock/Spring Lowering Kit (http://www.umiperformance.com/catalog/index.php?main_page=product_info&cPath=2_319&products_id=707)
Price: $1,099.99
Website Links:
