woody80z28
08-28-2012, 09:22 AM
Are there any no-no's with brake line bends & routing that are likely to trap air and make bleeding difficult?
I have been chasing a spongy pedal for quite some time. Tried different master cylinders & calipers and done what seems like a lifetime's worth of bleeding brake fluid. I've checked the master cylinders by plugging the outlet ports and it hydraulically locks. But when in the car, the pedal is spongy and never hits a wall. I can not get any more air out of the lines...tried pressure, vacuum, gravity and pump & crack. Even took it to a shop a while back to see if they had any tricks with no change.
Can the problem be in my line routing? I do have a couple loops between the master and front calipers because of my line lock routing. At no point is the line higher than the master cylinder, but I could potentially see it causing a place for air to get caught.
At this point I'm grasping at straws.
