View Full Version : Bill Mitchell Windsor Sr Heads and Edelbrock intake
1970 TT Rustang
08-19-2012, 04:58 PM
These heads and intake have less than 3000k
Casting ID Number: I-061
Material: High density cast iron
Valve Seats: Intake (integral), exhaust (hardened)
Valve Guides: Integral cast iron
Spring Seats: Machined for 1.560" and 1.250"
Valves: Manley stainless steel valves in assemblies (inconel exhaust valves on marine applications)
Valve Diameter: 2.020" intake, 1.600" exhaust (11/32" stem)
Guide Plates: Special World part #830460-8
keywords head afr trickflow svo sbf bbf currie moroso comp cams
Rocker Arm Studs: Screw-in style
Rocker Arms: Adjustable rockers recommended. 1.6 ratio (use of 1.73 ratio will require elongation of pushrod holes)
Intake Runner: 200cc, standard port location
Exhaust Ports: 64cc, standard location (dual exhaust bolt pattern to accommodate large custom headers)
Combustion Chamber: 64cc
Spark Plug: 14mm 5/8" .460" reach tapered style, Accel 276 or 276S or equivalent
Valve Job: Multi-angle intake and radiused exhaust
Valve Cover Rail: Raised
Valve Angle: Stock 20°
Accessory Bolt Holes: Stock
50-State Emissions legal
HEAD FLOW @ .600 LIFT
255 intake, 177 exhaust (Super Flow 1050)
272 intake, 191 exhaust (Super Flow 600)
The intake is a torker2 which is setup for efi
I also have lifters and push rods that can be sold if the price is correct
Iam asking 599 thanks
635386353963540
