View Full Version : 67-69 Camaro/Firebird 68-74 Nova Front and Rear Suspension
DEIGuy38
08-17-2012, 08:28 PM
67-69 Camaro/Firebird & 68-74 Nova Suspension
Checking to see if there would be interest in these parts. All of these parts have been used for mock up only. 0 miles on these parts.
FRONT Suspension Parts
Stock upper and lower a arms sand blasted and painted with POR15 with:
AFCO low friction greasable steel a arm bushings in the uppers and lowers. There is no preload on the arm like you have with rubber or urethane bushings.
Upper bushings were little longer than stock. I machined the front bushings only to move the cross shaft forward which will build more caster into the arms with out using shims. Bushings are tacked into the arms to keep from slipping plus bolted in like stock.
Howe Racing lower rebuildable ball joints with stock length shaft (have 2 extra shafts)
Howe Racing upper rebuildable ball joints with ½” taller length shafts to help camber curve
Howe racing rebuildable outer tie rod ends with ½” taller length shafts to help with bump steer issues. I have black and red dust boots.
Hotchkis front sway bar 1 1/8” hollow with greasable bushings/mounts
AFCO front coils springs 500# 5” dia. x 9.5” tall
Coil spring pocket adjusters (2” of adjustment) to be able to adjust ride height. These have a bolt welded on them so they can be bolted up in the spring pocket. The bolt would go in the factory hole in the frame behind the shock mount.
Just add the gmod to your subframe and your ready to go.
***Spindles and brakes are not for sale***
REAR Suspension Parts
Landrum Multi Leaf 200# springs. I was told by Landrum if you removed one of the lower springs they would be 175# springs.
Energy suspension urethane leaf spring bushings
Reason for selling is I bought DSE Quadra link rear suspension and would like to get one of their speed kits for the front. I will split the front and rear. I will not part out the front suspension, it all sales or nothing sales. I would like to get $ 1,000 plus shipping for all the parts. Let me know what you think. If you are interested let me know and I can send pics
The pic of the 69 is for example of ride height, has very similer setup for suspension
DEIGuy38
08-24-2012, 10:19 PM
Bump Nobodys looking for a budget suspension front and rear
DEIGuy38
09-21-2012, 09:23 PM
Added pics
