View Full Version : Accu-Link on a Roots blower
sporter
08-17-2012, 04:18 PM
If anyone has mounted an Accu-Link on a roots blower with side mounted Holley's, I'd love to see some photos of the installation. Thanks.
sporter
08-20-2012, 08:39 AM
Finally got everything to work together. I really wanted it below the hood line but I just could not get the proper ratio. Looks like I'll be putting the weather tight connectors to the test.
63546
63547
sporter
11-18-2012, 07:15 PM
Finally got it to work below the hood. A bit Rube Goldberg-ish but functional and the wiring is hidden. :cheers:
http://www.youtube.com/watch?v=VCQj6JzK3Xc&feature=youtu.be
67683
Steve Chryssos
11-19-2012, 05:21 AM
Is there any way to use one of the holes that is further from the hinge point? If not, then I suggest softening up the tables in the 50-70% range. As is, you have a rather steep motion ratio. The software CAN compensate, but I like to see a more gradual motion-- especially with that big honkin' blower. Sounds great!
sporter
11-19-2012, 07:27 PM
I tried the outer holes but the TPS was "bottoming out" and preventing me from getting more than about half throttle. I had to drill and tap a hole much closer to the axis just to match the limited arc of the TPS. The throttle is pretty stout with 6 springs holding it back. Seven if you count the TPS.:eek:
http://www.youtube.com/watch?v=Cn067fpt7yg&feature=youtu.be
6770267703
