806spd
08-16-2012, 04:53 AM
http://www.cachassisworks.com/p-1215-camaro-67-69-chevelle-64-72-nova-68-74-2-drop-tall-upright-spindle.aspx
These look like an effective solution to the expensive AFX spindles and they are way lighter than the B-body spindles I currently have. I am wonder if I can get these to work and if i do will I be better off than the B-body. Since the AFX spindle is the same between the G-body and the A,X,F except for the ball joint tapers and steering arms i would think that this would work.
Those who have tried, does the A-body spindle work on a G-body?
To be specific, do the ball joint tapers need to be changed to g-body tapers? I currently have b-body spindles so I might have to change the top ball joint or machine the spindle for b-body taper on the upper.
Is the upper ball joint at the right angle so that it doesn't bind at full travel? that way I can reuse my upper A arms.
With 4-5 degrees of caster, will the A-body steering arms work or at least are they high enough to use a bumpsteer kit to adjust the bumpsteer?
How will the steering arms effect ackerman angle and ratio?
Can I use the AFX bolt on G-body steering arms on these spindles?
I like the way the car handles with the B-body spindles but the bumpsteer makes it hard to place the car accurately at auto crosses and I would like to reduce the weight of the car but don't want to spend thousands on the AFX. I could get some G-body spindles and use the SC&C stage II plus but if I am going to get spindles I might as well get the lightest ones I can.
