View Full Version : Gauge Measurements.
JoshStratton
07-26-2005, 05:58 AM
Does anyone know how the gauge measurements work? Is it typically from the outside ring, or just the gauge itself?
CAMAROBOY69
07-26-2005, 06:55 AM
Generally if it sais its a 5" gauge then that indicates the outer ring. Here is an example of my Autometer Ultralite gauges.
5" gauges
Outer ring is approx 5"
Part you stick into hole is around 4.5"
2.2" gauges
Outer ring is 2.2"
Part you stick in hole is 2"
JoshStratton
07-26-2005, 06:57 AM
I have a warped fragile little mind :lmao:
Thanks for the info. I was never sure of that.
CAMAROBOY69
I understand. I was laughing the whole time I typed that. :lmao:
68protouring454
07-26-2005, 07:04 AM
i got me a monster tach, 9 inches, part you stick in the hole is 7.5
jake
Matt@RFR
07-26-2005, 09:03 AM
i got me a monster tach, 9 mm, part you stick in the hole is 7.5mm
There, fixed it for ya Jake. :angel:
JoshStratton
07-26-2005, 09:04 AM
Hahahaha. When will you learn. Its not the size of the gauge, its how you use it!
For example, use it to get down the track in 11 seconds or less.
