68lovebuzz
08-06-2012, 10:44 PM
Hello everybody,
Thanks ahead of time for answering my question; It may be obvious for some!
I ordered a moser 12 bolt with c clip eliminator, bolt-in axles. I tried installing the axles tonight only to notice the bearing pressed on to each axle sticks out nearly 1/8" past the bearing end welded on the axle tubes - (The bearing itself when installed is not flush with the brake mounting surface at end of cap). Does this have any significance at all? Am i over thinking this? Should I Just bold the retainer on an call it good? Thanks for your 2 cents on this matter.
These two shots show the bearing end and bearing pressed on the axle just as they were shipped.
6303663037
6303663037
