View Full Version : C6 spindle orientation.
keithq69
08-03-2012, 10:42 AM
Not sure if this should be posted on the suspension or the brake area, sorry if I picked the wrong one.
Is there any downside to using a C6 spindle and swapping them from left to right so that the caliper is now on the front of the spindle?
19,69camaro
08-03-2012, 12:18 PM
They have built in caster....what would be no bueno!
On the bright side that thing would be very stable going in reverse
keithq69
08-03-2012, 04:43 PM
I don't think they have built in caster.
As far as I can tell the upper and lower ball joint center line runs through the center of the hub.
If the spindle was swapped the upper ball joint could be moved back to gain the required caster.
