View Full Version : first gen camaro, pinion offset or centered?
dcrider69
08-01-2012, 05:56 PM
I think that they are centered from factory, but wanted to make sure. Is the pinion centered in the car, which makes each axle tube same length? Thanks in advance!
surnufz
08-02-2012, 05:04 AM
The pinion is in the center, but the axle tubes are not the same length.
AmKenpo1
08-02-2012, 05:13 AM
GM cars have a 1/2" pinion offset to the passenger side for steering box clearance.
Wil.
dcrider69
Because of the shape of the "center section" correct?
dcrider69
08-02-2012, 05:14 AM
Wil.
huh?
AmKenpo1
08-02-2012, 05:34 AM
Sorry, to be clear most GM cars have the engine and drive train offset to the passenger side for clearance. This causes the pinion to be offset also. Unless you have a chassis that was built for a centered pinion.
Wil.
