View Full Version : '69 Chevelle - Project TIMACHN
Barrrf
07-31-2012, 09:39 AM
PLEASE DELETE THREAD - Photo*****et killed it
Barrrf
02-07-2013, 04:49 PM
Even tho no one commented when I made this thread, Im going to update it anyways.
I have since installed 3 point seat belts. and reinstalled the a-pillars and dash board uncovered. I cant get the dash pad into the upholsterers until the 12th. So once thats done I'll slap the dash back on and take some shots. I did however, color match the tired old pitted tail light bezels and polished the plastic. Not sure if I like it yet or not.....or if I do like it should I repaint the black inside of the bezel or not.
Color Matched
Not
Progress is slow on this car - Im too busy driving it to work on it. And heres a pic for photography buffs (shot with Canon T3i)
Had the dash pad covered and stitched.
Only good pic I have of it now. Also shown is , gauge bezel painted, metal dash part painted silver along with column, A-pillars covered with soft touch vinyl (really nice stuff), kick panels redyed black, vents painted black, tach reloacted from top center of dash. Im going to call the dash area done for now until I can fund VHX gauges, new carrier, and ididit column. My next thing to do is find a nice steering wheel. Then in a couple weeks I'll start on the door panels - I figure this to be a good month long project.
I know the stitching isnt perfect. But thats fine, I wasnt expecting it to be.
I just ordered a slew of parts for the ride. Only a couple frilley pieces that you will actually see. Most of them are functional parts. The list is as follows -
New CS130 140amp Alternator. The current 63amp isnt powerful enough to run the car when I mash the pedal.
New core support. Current one is rusted out.
New polyurethane front suspension bushings.
New polyurethane body mount bushings.
3" Rear lowering springs.
4 new sealed beam conversion headlights with relay harness. I will be converting the low beams to HiDs with projectors for more BRIGHT.
New steering wheel.
Holley SA 770cfm to replace the overly large Edlebrock Q-Jet that is currently on there.
Not sure what to do on the front yet on my limited budget.
AM PSYCHO
02-07-2013, 05:15 PM
talk about mickey mouse
Barrrf
02-07-2013, 05:25 PM
I dont get it
Vortech404
02-07-2013, 05:43 PM
Bart,
Looks like it has alot of potential. Nice job with the dash cover. Keep at it.
Your driving your car and having fun and that's what it's all about.
Keep the updates coming.
John
KnightMare
02-07-2013, 07:51 PM
That interior looks way better then when you first started out. Hows the rest of the car look? Rusty areas?
Barrrf
02-08-2013, 05:12 AM
The trunk is rotted out where it curves up toward the lid in the back. The core support is rotten on the battery side - but I already have that part sitting in my garage waiting to be put on. The floor boards show very little surface rust, on both sides. The doors are original and solid. The front and rear quarters were replaced and a decent but not perfect job was done on those. Around both front and rear windows there are pin holes from rust - not suprising considering the design allows water to just sit in there. The only thing I could think of doing at this point is slather some goop in there to keep water from leaking into the trunk. Unfortunately, I dont have garage space to work on the car a lot so I have to wait for warmer weather when I can kick the wife out of the garage so I can use her spot.
The frame is solid. Or as solid as A-body frames can be anyways. I went around the lower curved area of the frame where the rear LCS connect and tapped on the frame with a ball peen. It made that nice metal "tink" noise and not that "thud" that you get when you tap on layers of rusted metal.
Its going to be a slow process. But its mine. And I dont want to be without driving it for weeks at a time. My goal is to do everything myself except for any welding or when the time comes, body work. I dont have the patience to do body work. What good body guys do blows my mind.
Oramac
02-08-2013, 07:20 AM
I'll race you for the Slowest Build Title. lol. :D
I do like the Pro-Tinker thing. That's pretty much what I'm doing with my Camaro as well.
Your Chevelle looks great! If I didn't know better I'd say you had a lot more work into it than you do. The interior is coming along nicely. Are you planning any major modifications to the interior, or just going back to semi-stock?
Barrrf
02-08-2013, 08:32 AM
My plan, currently (which changes when I keep finding things that need to be changed vs things I want to change), is to completely update the interior. Im working front to back - sort of. Once get the suspension sorted out so I feel safe, Im going back to the interior.
First thing Im doing is changing out the seats - and unless someone has had a terrible bad experience with Cipher, Im going with those. Then I'll probably buy a new gauge carrier and put VHX gauges in it. Im also going to be working on a center console subsequently. I have a few ideas Im kicking around in my head about the center console - but I know I want to have a couple of removable panels so when I change from a stick to a ratchet auto I wont have to rebuild the whole console. I also want to have a gauge pod off the left side of the console so the passenger can see RPMs/MPH without having to crane their neck over to the drivers seat. And lets be honest - that planet sized tach has to go.
And dont hate me too much, but Id really like at least 1 cup holder. Its hard to drive, shift, and hold my morning coffee all at the same time.
KnightMare
02-08-2013, 10:16 AM
Let me know how those Cipher seats work for you. I was wanting a pair of those when I get closer to getting finished with my Camaro
ekmxryda
02-09-2013, 05:40 PM
"longest (time wise, not post wise) pro-touring build maybe on the planet"
Ha I have you beat already! I started my GTO 27 years ago, and just started to work on it again last summer.
Don't listen to all the negative comments, just keep working on it and doing a little bit as you can afford it. Looks like you are off to a good start though, the body is nice and you can patch the floors later.
Nice to see more A bodies out there. Good luck.
Motown 454
02-10-2013, 02:32 PM
Your car looks nice. The dash looks great in there. Its nice your able to drive it while you work on it.
Barrrf
02-10-2013, 06:30 PM
Thanks fellas. That's kind of my goal - be able to drive it and do work on it. Part of the reason why it's not stripped down. I need to be able to drive it. Too much fun.
Barrrf
05-20-2013, 08:58 AM
Update: So I strayed from my original path of just replacing the core support and cleaning up the front suspension with some powder coat and new bushings. Whilst I did replace the core support, I also replaced the A-Arms and springs in the front, new alternator, lower alternator bracket (was missing), new CPP 3" springs in back, body bushings, and seats.
4/15/13 - Everything removed from drivers side. Gonna clean up the frame and paint before putting new stuff on.
Gross old stuff on the ground. It was at this point I decided to buy all new stuffs. I waffled a bit. But I got really frustrated with trying to remove the old bushings, so I chucked the a-arm and hit up ebay.
Rats nest behind the firewall. This is how it came to me. Its the horn relay (life of the car apparently) and the voltage regulator. 2 things that are curious about the factory build/wiring. 1.) The horn relay needs constant 12v power. Without it the car has absolutely 0 power. None. Cant even turn it over. 2.) All of the passenger side wires run in front of the core support on the outside of the car. I believe all of the wires were run and the connectors put on after that. Because I could not pull them back through - the connectors were too big. I had to cut 5 wires and put them back to together as a semi temporary fix.
4/19/13 - Grille, headlights,header panel, ect removed
Still 4/19/13 - Everything is off. Reassembly can begin.
4/30/13 - New A-Arms with Energy Suspension Bushings and Proforged ball joints with Hotchikis 2" drop springs. Im impressed the sway bar link are roto-joints. Not bad for cheap a-arms. .
*Disclaimer - I really really wanted UMIs with tall BJs but the coin wasnt there and I wanted to stretch my buck a bit further. So I bought these CPP A-arms for $279 shipped. I bought the Proforged BJs at the same time with the intention of swapping them out immediately. When the arms arrived, I disassembled them and installed the new bushings and ball joints. I also painted them silver - just because. What I did leave however, is the sway bar end links. The lower connection is a roto-joint as opposed to the OG bushing method.
Still 4/30/13 - Caliper bracket - steering linkage shot
5/4/13 - Painted new core support to install.
Another shot of some more stuff installed. Also, some wires just hanging around.
Some poly body bushings to show. Yes theyre on the whole car and not just right here.
Brackets and header panel reinstalled
Filler panel and headlights reinstalled. Used all new headlight bucket hardware and springs. Decided against installing retrofit projectors at this time because I just wanted to get the car on the road. Will install later - requires cutting headlight buckets and core support. So I just put in H4 highs (replaces T3s) and installed new relay harness. OEM wiring sends all headlight power through the headlight switch - makes for dim lights. Relays are the way.
5/5/13 - Forgot to take some pics along the way. So in this pic I have the fender wells reinstalled (painted silver), core support bracket reinstalled, and dirty **** reinstalled. You can also see new CS130 Alternator. It bothers me to no end to put old **** back on, but, this isnt an unlimited budget build. So I make due. I couldve cleaned some things up I suppose but I was in a damn hurry.
5/5/13 - Had old Edelbrock Q-Jet 850cfm carb on there. I bought this 770cfm Holley Street Avenger to use instead. Holy off idle hesitation batman. Took some research and some parts but it is tuned up and makes way more power than the Q-Jet did.
But I learned a lot about the Holley carb. Most people said the lean condition I was experiencing (popping out of the exhaust, off idle hesitation) was caused by vac leak or improperly set accelerator pump. So this gave a place to start. I removed the accel pump diaphragm and checked the primary squirter size. Everything seemed to be good there. I reinstalled those parts and set up a slightly more aggressive pump cam with a longer squirt duration. Still hesitated pretty bad but I could push through it and the car would move. So I bought a vac gauge and set the idle mixture screws, then the curb idle screw, and made sure the float levels were correct and also dialed the fuel pressure up from 4 1/2 psi to 6psi. Still a mean hesitation. Finally I decided to look at the primary and secondary metering jets. 68 and 76 respectively - yup, car is lean. Bought new jets and started with 72/76 combo. That almost did the trick - still a slight hesitation under light throttle. Went up to 76/82 - BOOM! MONEY! Now just waiting on my AFR gauge to arrive to see where I sit.
And on Friday 5/17 - New Seats and Wheel installed. The wheel is a flimsy piece of crap and I need to find a better one (thats my personal opinion about this particular wheel made by Forever Sharp. They may have better wheels I dont know. But the adapter parts that came with the wheels are awesome). I'll make due for now. The Cipher seats however, firm, good bolstering, solid construction - not bad for $340 shipped. Im am slightly concerned about the sitching - we'll see how well it holds over time. The biggest hit was buying the Planted seat brackets. $140 each. Theyre very nice brackets though.
And the lowered shots -
Forgot to remove SS plate. Oh well.
For the most part, everything went ok. Only one bolt on the passenger side lower A-Arm had to be cut off. Mostly everything lined back up which is lucky considering the nature of aftermarket replacement sheet metal. I had one issue with the headlight wiring, it was a ground so easy fix. Then I mentioned the no power thing - that had me stumped. I initially thought the POs terrible wiring job was the culprit - there was a random blue wire tied to battery +. Turns out random blue is pretty important to the life of the car so I ran a new red power wire to the horn relay.
So in the end, I have some nice new parts. Jury is still out on if it handles any better. I'll do my best to describe the before and after seat of the pants handling.
Before - car seemed to roll slightly then bite hard in sharp corners
After - car doesnt seem to roll. Seems to effortlessly glide through the corners. Giving the illusion the car isnt biting. Handling seems worse but I have more confidence in the corners.
Martin71RS
05-20-2013, 10:20 AM
sometimes i wished I had done mine in steps.....it took me years so I understand your approach...., like what you did to the dash, keep up the good work!
dpruden
05-21-2013, 04:24 AM
looking good. I like that you are doing it while driving it. its cool to do that way so you can find out the weak points as you enjoy it. very nice.
68firebird
05-21-2013, 06:41 AM
Dash looks awesome!! Love the chevelle, looks good! Great job so far. One day I'll splurge and get some tubular control arms. Its gotta handle better after doing all that! I noticed a huge difference and I didn't upgrade to the tubular arms. maybe you need to throw her around harder :drive:LOL
Barrrf
05-21-2013, 07:12 AM
I think youre right. Coming into work this morning I'll held the suggested 35mph corner to 70mph. Minimal body roll - easy through the corner. I never felt out of control or uncomfortable. Whereas before, it'd roll then snap into the corner. This must be what the suspension experts talk about when they describe the terrible factory camber of these cars and how the tire rolls over too much before the camber can compensate?
85coupe50
05-21-2013, 10:53 AM
My friend has a 69 Chevelle that he is going to be putting an LS????? into. He is looking to find a salvage CTSV with an LSA for it. Your Chevelle wears it's colors well.
Barrrf
08-02-2013, 11:24 AM
Slowly coming along. Tore out the back seat, pkg tray, side panels so I can fix quarter winders. Decided at that time I might as well make a custom pkg tray because that will be relatively easy. Also found this -
Why would someone cut all that out? So doesnt matter, I'll make it work.
About half way through - the tear drops are for 6 1/2" Components to mount underneath the tray on a sub plate. Theyre covered in speaker cloth. The others cut outs are for faux suede inserts.
and in the car -
Turned out looking better in the car than it did to me while it was laying on the ground. Next project - rear interior side panels.
Barrrf
02-17-2014, 08:51 AM
Got a few wintery things going on right now. Im going to attempt to make new door sill protectors out of real carbon fiber. I have the resin and cloth - just need to do it.
I started on those side panels. Need to make small arm rest cap and have them covered with 1/4" of foam and the same material I used on the dash. Still considering where to put the stitches tho.
Also doing an experiment with the tail light bezelz and smoothing them out to see how they look.
Oh and bought some of these -
Bonehead
02-17-2014, 01:51 PM
Hang onto that Edelbrock Q-Jet. You'll be surprised at what you can get for it. Dig the project! Nothing like fun in a Chevelle.
Auto Rod Technologies
02-17-2014, 04:23 PM
I like those wheels!! Post a pic when you get them on.. One good thing about doing it a little at a time while you drive it, you will know exactly what you have if you ever do decide to tear it down for body work.. Plus a lot of the expensive parts will be out of the way!
Barrrf
03-10-2014, 04:27 AM
Got my wheels put on. Im not in love with how the fronts look. Too much +offset resulting in little wheel lip. Too narrow. Or something. But the whole package cost me a little less than $1500. So I'll survive until a suitable replacement presents itself. (Please ignore the dirt, when I put it away for the winter it was raining). I may or may not space the front out a bit.
Wheels are TSW Snetterton 18x8 and 18x9.5 All ET20.
Tires are 245/40 and 285/35 Continental ContiSportContact3s
lugnut70
03-11-2014, 08:23 AM
I really like the rear, how its filled out. But the front...would a 18x8.5 looks better ?? or rub too much? Still looking very good
Barrrf
03-11-2014, 09:39 AM
Unfortunately that particular wheel only come in x8 and x9.5. Im going to experiment with it a bit in a couple weeks. Theres reports of guys running a 265 up front. So if I can get the wheel that on the back on the front too I may just go that route. Idk.
I just don't want to have to get the same wheels that every muscle car has on them - Boss338s or TT2s or similar.
lugnut70
03-11-2014, 10:01 AM
I like that you I wanted something different, that won't break the bank.
Thanks for posting updates!
csouth
03-11-2014, 10:59 AM
Its a very good start, nice color on the car.
240g
03-11-2014, 11:58 AM
Nice project, good move going in small chunks and keeping it drive able.
Barrrf
03-11-2014, 04:09 PM
Thanks for looking guys
Anyone want to buy 2 TSW Snettertons 18x8 ET 20? Never driven on!
130fe
03-25-2014, 08:26 AM
What is the backspacing with that 8inch front with ET20? The wheels look good!
Barrrf
03-25-2014, 09:14 AM
BS on an 8" Wide ET20 is really close to 5.25" (its actually 5.287). Here is a super fuzzy picture of 9.5s on front and back with 285s. I actually just dropped off the wheels to have the tires swapped about an hour ago. So I'll still have 245s on front they'll just be on an x9.5 instead of an x8.
ivanster
03-25-2014, 03:28 PM
That is one sick ass ride man
Barrrf
03-26-2014, 11:14 AM
Thanks! I mean I don't consider it to be a sick ass ride as there are some seriously sick ass rides here. But its mine.
WallaceMFG
03-26-2014, 12:36 PM
Looks good!
How is the front for clearance with the 285's on it? Any rubbing?
mc84_zz4
03-26-2014, 12:42 PM
Nice ride, the 69 Chevelle is my all-time favorite of the classics, and I also favor garage builds myself.
Keep the project stages to easy to bite chunks like you have, you get more drive time out of it.
Once you get to paint, you are in 'paint-jail' and it can drag along.
:cheers:
Barrrf
03-27-2014, 04:48 AM
Looks good!
I didn't drive it with the 285s on front. I just put one on the front to test fit the BS on the wheel. But I did mount the wheel and put the car back on the floor and turned to full lock in both directions. Plenty of clearance between tire and sway bar. "Enough" clearance from tire to rear of front fender. The only thing that might concern me if I were to do 285s is the clearance from the top of the tire to the fender but I only see that being a potential problem when turning hard and the weight of the car was transferred over. That would all be fixed by going standard ride height.
:cheers:
Thanks! Its hard not to just tear everything down fix the body work. BUT I want to drive it. Besides Im taking care of more important things first - handling then braking then moving faster while sprinkling side projects in here and there. Then I'll fix the metal stuffs.
lugnut70
04-01-2014, 08:50 AM
Two questions, hows the clearance on the rear tires, too the inner fender well? Also whats your current brake set up? Drums in rear, disks in front ?
Really liking the more meat in the front!!
Barrrf
04-02-2014, 04:40 AM
Current brakes are stock disc/drums. Stay tuned because I just bought some CTS-V calipers and am having the brackets to mount them cut as we speak. Just need new brake lines and 14" rotors.
There is about 1/2" of clearance between the tire and inner fender. Ive heard guys and have seen some pics of guys running 305 with a hair of clearance between the tire and inner fender and rolling the outer fender lip.
626Chevelle
04-04-2014, 04:21 PM
Thanks for posting the info on the tire and wheel package. People like myself are always looking to save a buck especially on wheels but we don't know what fits. I appreciate it and it looks good bro! I have a 68 Chevelle! Drive it!
Barrrf
04-21-2014, 05:04 AM
First drive of the season and first drive with new tires and wheels - launch traction is still an issue. Just drove it from this garage - to my house. Time to mount e-fans and A/C delete plate.
BossaNova
04-21-2014, 08:33 AM
Absolutely beautiful!
ed1le
04-24-2014, 08:43 AM
Is that the 245's on front? They look pretty good on the 9.5 wide wheel. Thought they'd look a little more stretched than that.
Barrrf
04-24-2014, 09:02 AM
Yes it is. Here is what they look like on the rim off the car -
https://static1.pt-content.com/images/pt/2014/04/Gp5Qp0c-1.jpg
https://static1.pt-content.com/images/pt/2014/04/H5JwaBc-1.jpg
youngmuscle
10-05-2014, 12:15 PM
I have 295s on my rear. Only had to very slightly roll the left rear, not bad. Our cars fit some good size meats stock. I have the typical rims you mentioned lol, they're Ridler 695 (boss 338 copy pretty much). I walked away with about $1400 all wrapped in nitto 555. Did a lot of research though. They are great quality, no pitting after 1.5 years, pretty light too. Overall impressed. I hear ya on everyone having those rims, but honestly I rarely see another muscle car, and I've never seen another pro touring car in person. They are absolutely the best looking rims you can put on a car to me lol. Pro touring cars and those rims may be common at a car show or this website lol, but in real life terms everything's pretty rare. 18x9.5 rear 17x8.5 front.
Definitely following you on the interior. I'm preparing myself mentally for winter in Germany with no chevelle while they salt the roads, but it does force me to focus on things. I, like you, refuse to do things that will take years as I love to just drive it, so I've done everything in stages as well. It's a lot more satisfying, plus you can see what each change does. This is her last winter in Germany so it's my last chance.
Your car is sick and it's really funny how I pretty much have the blue version of your car (same paint etc). I plan on starting a build thread in a month or 2, so I'll be pretty active especially with interior. I have a lot of access to European junk yards so I'll see what I can come up with (3 point built into seat etc). Love the car bro, keep the updates coming!
LS3torque
11-19-2014, 05:16 AM
Very sharp 69, just what I was looking for when I found my 68...
Barrrf
11-19-2014, 09:23 AM
Thanks for the comments! I appreciate them. I came off the wrong way about the Ridler/TT2/338 wheel comment. I really like the looks of them but, opposite of your situation, every imapala/Camaro/chevelle/nova/mustang that has custom wheels has those 5 spokes. Having said that, I went and bought pretty common protouring wheels. LOL.
My interior progress really stalled. I made the panels for the back seats then just kind of quit and drove the car all summer, and fished, and built bunk beds. Im hoping to finish the rear portion of the interior this winter and start on the front console and door panels. Really looking forward to seeing your build thread!
When I found my car, I really wanted a '67 but a deal presented itself and I took it. Going to be a life long relationship with this car but will be worth it all.
HELLCAMINO
04-20-2015, 02:53 AM
The same reason I got TSW's on both of mine.
Have the same issue with fronts. I got the Amaroo's in 18x8.5 and 18x10.5. I needed a 3/4 spacer to bring all 4 out a bit. I am running 3" ARP wheel studs also.
https://static1.pt-content.com/images/pt/2015/04/no20stick_zpsnh0j3oez-1.jpg
The Elco has 18x9.5 Valencia's with only a 1/2" spacer for rear.
https://static1.pt-content.com/images/pt/2015/02/CAM01377_zpslhbpuujf-1.jpg
primo
09-03-2015, 03:31 PM
nice car bart very nice
Barrrf
09-04-2015, 05:02 AM
Thanks! I have more pics to post for the year but..................am lazy. Lol.
Barrrf
05-25-2016, 09:53 AM
Damn, Ive not posted much here.
Ive installed speedhut gauges (GPS Speedo) -
https://static1.pt-content.com/images/pt/2016/05/XKJS6CC-1.jpg
https://static1.pt-content.com/images/pt/2016/05/tX35bIP-1.jpg
And I started working on the rear end.
Tore out rear end -
https://static1.pt-content.com/images/pt/2016/05/sg1d7sh-1.jpg
Pic of dirty rear end, less brakes and lines. Notice the UCS bushings not really pressed in all the way. Actually only in half way.
https://static1.pt-content.com/images/pt/2016/05/uT1iVo9-1.jpg
Got some stuff assembled. New brake lines, calipers, paint, yada - oh, and also hammered the bushings all the way into place.
https://static1.pt-content.com/images/pt/2016/05/SwI2cRO-1.jpg
Then I started reassembling. I got 3 of the 4 control arms in place. The drivers side UCA wouldnt line up. I know the 10 bolt has more clearance than the 12 bolt around the housing where the bushings press in. I checked the clearance on the drivers side and see the UCS is hitting the housing. No big deal, I'll pull the UCA and grind off a bit for clearance. Then I saw it -
https://static1.pt-content.com/images/pt/2016/05/wJJ3R7J-1.jpg
So I couldve had it welded up. But I decided that since the car is down 2" and I have almost 0 degree pinion angle that now was the time to buy adjustable UCAs. Theyre set to arrive Thursday from Spohn performance. Hopefully I can get this pig completed. Taking way too long to do a simple brake job.
Im praying for minimal pad knock back at this point. I'll report back.
Protour_Pinto
05-25-2016, 11:50 AM
Your car is in pretty good shape for Michigan. At least you found the crack now instead of on a launch or big sweeping off ramp.
I too am taking the long path on my project and doing a complete drivetrain, suspension and frame swap. Build it all before tearing the truck down since I need it for work
Barrrf
08-10-2017, 09:50 AM
Mods, please delete thread because photobucket screwed it.
