View Full Version : Chevelle front suspension help
Loyaltyisking
07-17-2012, 01:43 PM
So I was trying to find some info about the space between the lower control arm bump stop and the frame.
I have a 66 Chevelle with CPP upper and lower control arms, and QA1 coil overs. I was wondering if any one had some thing I can reference as to what the space between the lower bump stop and the frame should be at ride height? Or any help with this? Im a newb in suspension related stuff. To give a little background- when I installed the coil overs i bottomed em out, so when I lowered the car to check the look I noticed the frames on the bump stop. I love how the car sits as is.. so what ever I can do to retain the height I want to try first. Again I am new to suspension. So dont get all crazy with the lingo..
andrewb70
07-17-2012, 03:05 PM
The position of the bump stop is not really relevant because different control arms put the bump stop in different places and the bump stops can vary in height. On A-bodies, you don't want the suspension so low that the lower ball joints are above the lower control arm pivot point on the frame.
exwestracer
07-17-2012, 03:49 PM
^X2^. Leveling the lower arms at ride height is the best starting point for the suspension.
Loyaltyisking
07-17-2012, 03:57 PM
Well right now the ball joints are pretty much at the same level as the pivot point on the frame.. I should raise em right? Also if I raise em to where the ball joint is clearly under, would it be an issue if I trimmed the bump stop? (to get more suspension travel?) I know drag peeps do it. Would it hurt or help me? I want a pro touring car in the end
Loyaltyisking
07-17-2012, 03:58 PM
Leveling em to where their parallel to the ground?
UMI Tech
07-17-2012, 07:13 PM
We put the pivot of the ball joint roughly an inch below the suspension pivots. This is a somewhat loose measurement as there are angles involved in the lower a-arm pickup pointa As the suspension travels in bump, the lower a-arm tends to stay flat or slightly past flat. This flatness, like Ray eluded to, minimizes track width change and just plain keeps things working properly.
UMI Tech
07-17-2012, 07:14 PM
Oh, and don't forget due to motion ratio, roughly one inch of bump stop clearance yields two at the wheel.
