View Full Version : 69 camaro blow thru
layinlow3
07-15-2012, 11:26 AM
454 with vortex blow thru with carb box fuel pressure vaccum source were to hook it to no fuel on start up magna fuel 325 pump with magnafuel regulator when adjusted to get car run floods fuel out of carb what is the proper hook up for vaccum source to regulator
DButler
07-15-2012, 12:31 PM
It hooks to your carb hat so when boost is in carb hat pressure will raise...if it is hooked to manifold pressure will rise to late....boost reference port has nothing to do with it having no at start up though.
DButler
07-15-2012, 05:09 PM
Also if it floods out top of carb either your return line is too small or your floats need lowered on car. What size is return?
Barrrf
07-16-2012, 11:20 AM
Add reps to DButler for being able to decipher that mess..........
tellyv
07-16-2012, 12:41 PM
Pocket replied!
shmoov69
07-17-2012, 08:00 PM
Wow!!! Is that how the new generation talks?!?!?
JEFFTATE
07-18-2012, 05:39 AM
It must be texting shorthand ..
