View Full Version : Eastwood mig welder
5spd540
07-14-2012, 12:04 PM
Anyone have any experience with one of these?
5spd540
07-15-2012, 09:23 AM
nobody has one????????
zombiekiller
07-15-2012, 05:43 PM
i've got the 175. If you know how to weld, its a great deal. I think you'll tend to struggle if you're just starting out.
i use it for my heavier fab. I use a miller 140 autoset for thinner metal as the eastwood tends to blow through anything 16g and thinner pretty easily.
5spd540
07-15-2012, 06:38 PM
I do know how to weld. I was looking at the 135
nestockcar
07-24-2012, 12:32 PM
I have the 135. I think it welds fairly good, even been able to do some thin materials...carefully. But the costruction is kinda cheep, lot of plastic, which tends to break easy (the side door hinge has broken on mine). Also, the drive motor is weak, so you have to play with setting the wire spool tension a bunch to get it running smooth. I think for basic hobby use it is ok, I still use it often.
justin51986
07-24-2012, 12:46 PM
Lincoln. the only way to go.
5spd540
07-26-2012, 02:25 PM
I went ahead and got a 140 lincoln
