View Full Version : Rust converter products, what to use?
corty1980
07-13-2012, 08:12 PM
Hi Guys,
Iam restoring my 1975 Ford Cortina and had paint stripped the roof to discover this. The car has a fair bit of fairly heavy surface rust. Any suggestions on how to fix this, what rust converter product to use?
62034
62035
robscar
08-01-2012, 01:51 PM
I've tried the POR-15 rust convertor, which is called Metal Ready. I would imagine most would do the job you want.
Rod
08-01-2012, 02:19 PM
I use products from this company, called The Safest Rust Remover (http://www.safestrustremover.com/) the stuff is great I haved saved a lot of parts I couldnt replace
astroracer
08-01-2012, 02:46 PM
I call Metal Ready a rust "remover". It will remove surface rust as you have it on your roof. I would build a little dam around the rust and pour the MR directly on it. Let it soak for a while then work it in with a small wire brush. Scrub the whole area with some maroon scotchbrite, you will be amazed with the results. AND WEAR RUBBER GLOVES!!!
Mark
72'Monte
12-06-2012, 09:51 PM
i went to home depot and got a gallon of rust remover.it works great.
