View Full Version : GM LS3 crate motor connect +cruise - opinions?
cartel
07-11-2012, 08:58 PM
looking to put a ls in old chevelle--
was looking for a ls2 take out but no luck locally..
http://www.jegs.com/i/Chevrolet-Performance/809/CPSLS34L65E/10002/-1?parentProductId=
found this today $11k.. with trans just need pulleys..
how good is the ECU?
neki67
07-12-2012, 01:44 AM
ECU seems to be the E67 as in in the GMPP LS3 controller kit; http://www.jegs.com/i/Chevrolet+Performance/809/19258270/10002/-1 or http://paceperformance.com/i-6255503-19258270-gmpp-ls3-controller-kit-for-ls376-430-contains-pre-programmed-ecu-harness-sensors.html
Most advanced ECU GM is using with fastest processor speed. Completely tuneable with e.g. HP-tuners or EFI-live even when at a later stage you decide to go Forced Induction.
For OEM dependability, throw in one of these for pulleys:
http://paceperformance.com/i-6485405-19155167-gmpp-accessory-drive-system-without-a-c-fits-ls2-ls3-ls7-engines.html
or
http://paceperformance.com/i-6255430-19155067-gmpp-accessory-drive-system-with-a-c-fits-ls2-ls3-ls7-engines.html
Obviously you'll still need/want some other odds and ends, e.g. motor mount adapter plates, fuel system (pump, tank, filters, lines, regulator), headers (?), oilpan (?), etc.
