View Full Version : NAPA C-5 front caliper?
brownz
07-11-2012, 04:31 PM
I'm looking to do a tight budget build on my 72 nova and want to do a c-5 front brake set-up. I priced around and KORE3 has about the best price for the c5 zo6 calipers. So after that I called NAPA and they sell the caliper with bracket for $75. They are not red and they do not have the corvette on them but that really doesnt matter.
My question is would these be a good part to use?
Has anyone used them?
What are the differences?
Any info on this set-up is welcome
chuckd71
07-11-2012, 04:40 PM
For that price does it come complete or do you have to buy all the little parts separately?
brownz
07-11-2012, 04:48 PM
the calipers and bracket is complete with pins ect. Just need to add pads and rotors, plus the KORE3 adapter kit and lines
amargari
07-11-2012, 06:10 PM
I believe that is without the core charge. You need an old one to turn in. The core charge could be around $67.50.
carguykeith
07-11-2012, 06:50 PM
I got mine used on fleabay for about $150 for the pair with abutment brackets, pins, pads and even the hoses . That was a year or so ago, should be even better pricing now?
brownz
07-12-2012, 03:49 AM
yep they do have a core charge but I should be able to find some to turn in so that helps with the overall cost.
Just really want to know who makes them and if they would be worth the money or just get the PBR calipers
NoMoneyZ
07-13-2012, 09:23 AM
Start browsing the corvetteforum. I got a set of front and rear for 150 shipped a couple weeks ago. Added a brake motive rotor and pad kit for 110 shipped. Using Kore 3 brackets and lines.
Tony_SS
07-13-2012, 09:30 AM
I trust Napa parts more than I do the other chain stores... I would feel good about running those calipers. I used a Duplicolor spray paint for calipers... it's held up great.
brownz
07-13-2012, 11:03 PM
I have been keeping an eye on the vette forums but no luck yet
73RSZ28
07-15-2012, 05:50 AM
Contact Marc at Vettenuts.net he will hook you up.
Jeff70
07-15-2012, 03:51 PM
Try Rockauto.com
brownz
07-15-2012, 04:47 PM
I will be getting a complete LS1 front and rear set-up for $90 so I will just be using the LS1 fronts to save some money. I think they will perform well for a street car, and for the price I cant beat it.
Any thoughts on the LS1 fron brakes? is it a waste of my time or a good idea to save some money?
srh3trinity
07-15-2012, 04:53 PM
They are good calipers, but the stock rotors warp easily. One of the bigger suppliers had a brembo made replacement that was supposed to be pretty good.
Vicinity
07-15-2012, 04:54 PM
Their basically the same as C5 calipers. I think the C5's are a little stronger, but braking-wise, negliable difference. The LS1 brakes will do great.
But go for the C5 brake brackets and C5 rotors, it'll definitely be a noticeable upgrade.
brownz
07-16-2012, 03:44 AM
So it looks like I will just try and find some used C5 calipers and brackets. I would hate to install the stock LS1 fronts and not be happy with it, just trying to save some money where I can. The search continues...
Vicinity
07-16-2012, 04:43 AM
You wouldn't notice a difference in the calipers. The C5 rotor upgrade is common among the 98-02 Camaro owners as it virtually gives them a complete C5 upgrade.
Tony_SS
07-16-2012, 12:06 PM
I have LS1 calipers and they work well in a 17" wheel... very happy with the setup.. adding the rear disc was even better.
Is that a 13" rotor.. and it just as easy as adding the new rotor? I know... I should google this..
Vicinity
07-16-2012, 01:31 PM
Basically. You need the brake pad abutment bracket, c5 pads, and a c5 rotor. Give Tobin a ring, he has them in stock. He talked me through the entire upgrade. You end up with almost everything being C5 parts except the caliper.
EDIT: You must also have the correct conversion bracket, otherwise the caliper won't seat correction on the larger rotor.
Tony_SS
07-17-2012, 08:11 AM
Thanks Dan... that might be something to look into. For now I'm really happy with the LS1 front/rear setup.
