View Full Version : Spinning wheel stud - how to get lug nut off??
Toadman
07-11-2012, 03:37 PM
OtI have a wheel stud that is spinning loose inside the rotor, so I can't remove the lug nut. Anyone have any tricks to get the lug off? Preferably without damaging the wheel.
dgrown
07-11-2012, 03:54 PM
If I was in your position I'd un do my brakes pull the cover off the rear diff, pull the c clip and pull the hole axle out and grind the back side of the stud off and pull it off
astroracer
07-11-2012, 04:11 PM
Pull the the rotor? Can you remove the caliper with the wheel in place?
oestek
07-11-2012, 06:38 PM
Wow, that's a crappy problem. Now I'm puzzling over it. Do you have access to a lug nut splitter? That would blow the nut off and then allow you to get the wheel off to replace the stud. If not, a small cut off wheel on a Dremel can cut the nut on 2 sides and you can use a chisel to split it.
robertjra
07-11-2012, 07:21 PM
This is something that I have to deal with once a week or so, if you can give me the year make ect... I will walk you step by step its not as bad as you think most every thing you need is in your tool box
Toadman
07-12-2012, 12:08 PM
Got it!!!! I have long studs with open ended lugs. I drilled lots of small holes around the face of the lug to weaken it, then popped it a few times with a chisel until it came loose. Masking taped the hell out of the wheel so miniscule damage to it! NEVER want to run into that again!
oestek
07-12-2012, 12:45 PM
Good for you Todd. Glad it didn't turn into a major ordeal!
Keithr
10-24-2018, 01:16 PM
Front passenger side lug and stud both spinning and can't get tire off. HELP
icemanrd19
10-24-2018, 02:33 PM
Put a socket on the lugnut using a craftsman max access socket and drill the lugnut off.
