View Full Version : FS: 1991 Z28 LS1 T56 6 Speed
fast377
07-11-2012, 11:34 AM
Up for sale is my 1991 Z28. I don't have the time for it anymore, and I have recently gone back to school so I could use the money. It's been my baby since 1999, and a project ever since. Now that it's pretty much finished, I just don't have the time for it. I'm tired of moving it and spending money on it. It just sits in the garage under a cover. My build thread is here: http://www.thirdgen.org/techboard/ltx-lsx/573372-91-z28-ls1-t56.html. I will post a few pics and the details below. Car was stripped down to bare metal and refinished. Lots of time in that. Pics aren't the greatest, and definitely don't do it justice.
https://static1.pt-content.com/images/pt/2012/07/52-1.jpg
https://static1.pt-content.com/images/pt/2012/07/53-1.jpg
https://static1.pt-content.com/images/pt/2012/07/56-1.jpg
https://static1.pt-content.com/images/pt/2012/07/trunk-1.jpg
https://static1.pt-content.com/images/pt/2012/07/seat-1.jpg
https://static1.pt-content.com/images/pt/2012/07/headlights-1.jpg
https://static1.pt-content.com/images/pt/2012/07/enginebay3-1.jpg
https://static1.pt-content.com/images/pt/2012/07/enginebay21-1.jpg
https://static1.pt-content.com/images/pt/2012/07/enginebay1-1.jpg
https://static1.pt-content.com/images/pt/2012/07/dash-1.jpg
Tubular K-member: custom made piece from PA Racing, strengthened for road racing and incorporates mounts for a Ford rack and pinion
Front tubular control arms: Made by BMR
Spindles: Fabricated by Racecraft inc, incorporate a 2" drop and have a shortened steering arm for the rack and pinion
Struts: made by Koni and are adjustable
Upper strut mounts: Made by Spohn, large improvement over stock
Front coilover kit: Made by Spohn, allows for adjustable ride height
Outer tie rods: they are a bump steer kit made by Baer brakes
Rack and pinion: stock piece made for a ford Thunderbird
Front brakes: Brembo 4 piston calipers with 14" rotors
Brake lines (all): Made by inline tube
Radiator: new aftermarket replacement
Rear end: stock unit from the donor car, but was rebuilt with new bearings and seals, Torsen diff and Richmond 3.73 gears
Rear shocks: Koni adjustable
Rear coilovers: made by Koni
Panhard bar: Made by UMI, tubular, rod ended, fully adjustable
Panhard relocation: Made by Founders inc, offers more room around the axle for exhaust to be routed
Exhaust: fabricated with mandrel bends and a pair of Borla S type mufflers
Wheels: Made by Forgestar, lightweight, fronts are 19x9 rears are 19x11
Tires: Hankook ventus V12 Evo, fronts 275/30/19 rears 295/30/19
Engine: LS1 block, fully machined
Rotating assembly: Mahle forged pistons, Mahle file fit rings, Scat rods, new oem crank, Clevite bearings, fully balanced
Camshaft: Lg Motorsports G6X3
Lifters: LS7 racing lifters
Oil pump: new ported LS6 oil pump
ARP Head studs
Crane roller rocker arms
Push rods: Comp cams
Heads: stock casting 799 heads, with patriot gold dual valve springs, titanium retainers, and locks
Gaskets: all new and oem
Intake manifold: Fast 90mm
Throttle body: Nick Williams 90mm
Fuel rails: Fast billet rails
Injectors: OEM gm 32#
Trans: stock t56 speed gear box
Clutch: Textrailia twin disc clutch
Hydraulics: New OEM clutch master and slave cylinders
Shifter: New, made by B&M
Hood: Made by VFN and is an ultra light weight fiberglass piece
Weatherstripping: All new and OEM GM
Carpet: new, made by ACC
Seats: New racing style with openings for racing harness
Roll bar: New, made by Comp Engineering
Steering wheel: New made by Momo, suede wrapped
Fuel lines: New, custom braided lines
Power window motors: New, OEM pieces
Belt moldings: new, OEM
I've only driven the car around the block a time or two. It's never seen any street time since I finished it. So there is a chance a couple of bugs will arise once it gets driven. Not uncommon with total builds. It should only need minor adjustments. It does not have ac, but the provisions are there if you wan to add it. It has a new heater core, but I don't have any of the hoses or dash controls connected. Should be easy to set up if you want it (When I built the car, I planned to race it so I didn't need heat or air).
I'm sure I'm forgetting stuff. It's been a big build spanning several years. I had it appraised earlier this year, and it appraised for $24,500. I have well over $50,000 invested.
I would like to get around $14,000. PM for questions.
Open to all reasonable offers...would like this gone soon
Clean title.
Located in southern Georgia.
BADNBLK
07-11-2012, 12:50 PM
I watched this build progress, and I am truely sad to see it up for sale. No corners were cut in any parts of this build.
Someone will get an amazing car!
fast377
07-13-2012, 03:18 AM
Thanks! I hate to let it go, but I have other priorities right now.
19,69camaro
07-13-2012, 06:00 AM
That car is the cleanest looking 3rd gen I have ever seen! Major props for detuning the Redneck out of it. Someone will be getting a hell of a car for that price. GLWS
fast377
07-14-2012, 10:49 AM
Thanks! I worked quite hard on it...I think it turned out quite nice :)
GeoffP
07-15-2012, 05:33 PM
Very nice! Hope it goes to a good home!
fast377
07-17-2012, 04:27 AM
Thanks! I do too...and hopefully soon.
dropit69
07-17-2012, 06:36 PM
Holy crap thats sweet...!! if my other house sells soon ill be a calling..GLWS
fast377
07-18-2012, 11:35 AM
Thanks! Based on your sig, I think it would make a nice addition to your collection! Sell that house! :)
Cannon
07-25-2012, 12:15 AM
3rd gens get no respect, if only more ppl would build them like this! Nice job man.
fast377
07-29-2012, 04:27 AM
Thanks! I agree...you rarely see nice third gens. Stock or otherwise. But, when done right, I think they make really nice cars.
SLO_Z28
07-29-2012, 09:11 AM
I want this thing so bad! I cant afford it though :( . Good luck with the sale, this thing is badass!
fast377
07-29-2012, 10:45 AM
Thanks! If you (or anyone) wants to borrow money from the bank, I can email the appraisal for the car. Should be able to get a loan with that.
fast377
08-08-2012, 05:48 PM
Someone need to give this a nice home.
fast377
08-10-2012, 09:25 AM
Feel free to shoot me some offers...I would like to sell soon.
Chevrolaine
08-10-2012, 09:31 PM
Beautiful car, good luck!!
fast377
08-13-2012, 03:32 AM
Thanks! I would like it to go soon...accepting reasonable offers.
fast377
08-16-2012, 03:10 AM
Small price drop. Now $15,500 OBO
fast377
09-05-2012, 04:46 PM
Open to reasonable offers.
fast377
09-15-2012, 02:29 AM
Price dropped to $14,000
fast377
10-10-2012, 04:32 PM
Bump.
abowman
10-11-2012, 09:29 AM
PM sent
abowman
12-31-2012, 07:10 AM
Jeff,
Sent you a PM.
Hope all is going well,
ab
04ctd
01-01-2013, 06:09 PM
would you want a big diesel 4x4?
got it on trade, would have to be an even trade, I got soaked taking it in:
either here:
http://motors.shop.ebay.com/04-ctd/m.html?
or here:
2001 Dodge Ram 2500 Built Cummins Built Tranny Lifted 4x4 (http://cgi.ebay.com/ebaymotors/Dodge-Ram-2500-Built-Cummins-Built-Tranny-Lifted-4x4-35s-20s-Edge-35s-20s-4x4-LIFTED-SLT-CRUISE-Sony-/160948446725?pt=US_Cars_Trucks&hash=item2579466605)
fast377
01-02-2013, 05:16 AM
either here:
or here:
No, thank you.
fast377
01-06-2013, 09:56 AM
videos
https://static1.pt-content.com/images/pt/2013/01/th_VIDEO0002_zpsabdf5707-1.jpg (http://i893.photobucket.com/albums/ac137/fast377/VIDEO0002_zpsabdf5707.mp4)
https://static1.pt-content.com/images/pt/2013/01/th_VIDEO0001_zpse38aef08-1.jpg (http://i893.photobucket.com/albums/ac137/fast377/VIDEO0001_zpse38aef08.mp4)
https://static1.pt-content.com/images/pt/2013/01/th_VIDEO0007_zps278aa013-1.jpg (http://i893.photobucket.com/albums/ac137/fast377/VIDEO0007_zps278aa013.mp4)
1Bad68camaro
01-08-2013, 06:28 PM
Either all those vids are upside down, or these pain meds are really kicking in.... nice car tho. Really wish I could afford to buy this for my brother. Thats his dream car. GLWS
qnitro
01-08-2013, 07:33 PM
Love this car...If I wasnt in Smog Hell I would snatch this up...
fast377
01-12-2013, 05:12 AM
Sold!
cubicylndr16
01-12-2013, 06:26 AM
Sold? Payment confirmed? I anything happens let me know asap.
