View Full Version : Oil accumulator plumbing - LS1 with headers
Toadman
07-11-2012, 10:08 AM
I've searched here and on LS1Tech.com without coming up with an answer. Installing a Moroso oil accumulator in my '77 Camaro, and I planned to use the sandwich adapter, but it puts the lines almost up against the headers (modified 4th gen. Pacesetters). Thought about using a remote oil filter, but the lines would still be very close to the headers. Any other techniques for plumbing an accumulator? Or should I just wrap the lines in some heat wrap?
Toadman
07-19-2012, 04:16 AM
Bump
Toadman
07-19-2012, 12:43 PM
Hmmmm. Afternoon bump?
68sixspeed
07-19-2012, 03:22 PM
I'm not sure on the ls1, but on the LS7 there is an oil plug on the drivers side of the block at the front near the motor mount. (hex key plug) There is another plug on the passenger side by the starter.
another idea is to run an oil cooler and "t" it into those lines, the oil cooler is in the pressure loop.
68sixspeed
07-19-2012, 03:56 PM
One other thought, can you put a "t" in where the oil pressure sensor is at the back of the intake? That is a pretty big port at least on my motor.
Toadman
07-20-2012, 06:37 AM
Thanks! I'll look into both of those ideas!
