View Full Version : Short body to frame bushings. Anyone make them?
NoMoneyZ
07-10-2012, 09:47 AM
Looking to see if anyone make a shorter than stock body mount bushing. My car is in two pieces at the moment and would like to know. Planning on painting the frame this weekend and hopefully start assembly. If nobody makes them then I'll just go with the poly replacements.
67rally
07-10-2012, 11:36 AM
DSE makes them for the F Body. Not sure who/if anyone makes the for the A Body.
NoMoneyZ
07-10-2012, 02:23 PM
I should've put that in the title. I'm looking for an A body.
67rally
07-10-2012, 03:33 PM
Why do you want the half height bushings? I know some people have had issues with trans tunnel clearance with the F Bodies.
Is this for ride height or something else?
NoMoneyZ
07-11-2012, 11:45 AM
Ya, was just looking for a little more low. I have 1" springs and am getting tall ball joints. Just thought a tiny bit more without moving the suspension would be perfect. I don't mind the trans tunnel having to get a little beat on if needed.
ChevelleNV
07-11-2012, 12:20 PM
Well ABC performance makes solid body mounts for the A-Body, you might want to give the a call. maybe they can build you a half height set or worse case you buy a set and have someone chuck them up in a lathe and cut them down.
http://abcperformance.net/othercoolparts.html
I have dimensions if you want to build your own. PM me if you want them.
mikes2nd
07-17-2012, 08:12 AM
buy a poly kit and start cutting...
