View Full Version : Ring gear bolts came loose
69importkilla
07-09-2012, 11:55 AM
So my car got towed home today. 3 of the bolts on the ring gear came out and were bouncing around. No damage to the gears thankfully, but as I checked the other bolts they are all loose.
Question is: Can I put new bolts in and try it from there? Is there anything else I should look for?
HarleyR
07-09-2012, 07:09 PM
Safety wire them.... ARP Usually makes bolts that come pre drilled ..if not drill them yourself....
Chevelle598bb
07-09-2012, 07:40 PM
If the gears don't have damage then throw a new set of bolts in with red loctite. Then check the wear pattern. Safety wire is a good idea but you have to take the carrier out. I have never had a failure from the ring gear fasteners backing out. I have only safety wired one set if ring gear bolts and that is the 9 inch carrier i am using now.
Randy67
07-10-2012, 05:19 AM
Carefully check the gears for any damage, if none then you should be okay.
A buddy had two bolts back out on his Ford 8.8 with a loud bang. He was able to still drive the car, but when we pulled the cover, the bolts were a mangled mass and the ring and pinion both had broken teeth. It also took a chunck out the posi carrier as well.
69importkilla
07-10-2012, 05:47 AM
Well the gears the check out OK, I pulled each bolt out one at a time, cleaned it and the threads in the ring gear, used blue loctite and reinstalled the bolts. The cover was damaged by one of the bolts so I have to get a new cover before I can tell if everything is OK....
Side note: Finding a dif cover for the orignal 8.2 is difficult. Anyone know of anyone making non-chrome repoductions?
69importkilla
07-10-2012, 04:44 PM
Just wanted to update:
Got everything assembled and took the car out, everything sounds good! Thanks for the help guys...
badazz81z28
07-11-2012, 04:06 PM
Did you initially put red loctite on the bolts? You usually dont see them back out.
Chevelle598bb
07-11-2012, 04:45 PM
Red loctite is used not blue.
badazz81z28
07-11-2012, 06:05 PM
+1
You want those bolts to stay in place! Blue is for smaller diameter bolts.
07-11-2012, 09:00 PM
I had them back out twice with red loctite on an 8.5" rear axle. Found out the aftermarket bolt heads were 5/8", stock was 11/16" but I hadn't even looked at the old open carrier I pulled out. The 5/8" heads only have around .060" seat on them & they were embedding into the cast iron carrier & coming loose.
I was told they would work if a hardened washer was used.
69importkilla
07-12-2012, 03:17 AM
To answer, I never assembled the rear gears, I bought the car with the rear end as is. After removing the bolts, I did notice there was no locking compound on them whatsoever. I nstalled new bolts with hardened washers and blue loctite. I was weary of using red...
Hey guys thanks for pointing out I should have used red loctite after the fact!!! :)
sccacuda
07-12-2012, 05:13 AM
Yep, on the cheaper gear sets, the bolts have smaller heads that will come loose. You can use a washer, but I prefer to use the factory bolt. It doesn't come loose.
badazz81z28
07-12-2012, 06:02 AM
Seems very few if any have the larger head bolts anymore. I was lucky to find a guy who had NOS Mr Gasket bolts on Amazon.
BonzoHansen
07-12-2012, 08:02 PM
deja vu, the bolt issue just came up at nastyZ, same end result.
http://www.nastyz28.com/forum/showthread.php?t=244801
69importkilla
07-13-2012, 03:54 AM
I just checked nastyZ and those pictures are identical down to the diff cover's damage to my car!
Chevelle598bb
07-13-2012, 04:51 AM
I did mention red loctite in an earlier post. :)
69importkilla
07-13-2012, 05:00 AM
Ha! I noticed it "cough" after the fact....
I have to practice my reading comprehension skills!
badazz81z28
07-13-2012, 06:05 AM
Ouch!
Good thing I ran across Freddie's bolt warning years ago! I was very anal when I rebuilt mine. Those proper GM bolts are not that easy to find. Only a few seem to have them and they are a little pricey.
69importkilla
07-13-2012, 06:34 AM
I'm curious about this GM bolt thing. Couldnt you just subsitute grade 8 fasteners with hardened washers??
BonzoHansen
07-13-2012, 07:06 AM
if you follow that link, freddie lists a washer he has used in a pinch. and those bolts are LH thread.
"Any time that I use these bolts I put a hardened steel Ford washer under the head to prevent this from happening"
08-03-2012, 08:08 AM
I got some large head bolts from Summit Racing, I think they were Mr Gasket. The first set with small heads were Raetech brand on a new Eaton Positraction install.
69importkilla
08-03-2012, 08:19 AM
Is there any reason someone couldnt just use grade 8 bolts with hardened washer's?
BonzoHansen
08-03-2012, 08:58 AM
LH thread?
69importkilla
08-03-2012, 09:06 AM
Looking at them in the McMaster-Carr catalog right now.....
08-05-2012, 10:04 AM
What size heads? 5/8" is a standard head for a 7/16" bolt, you need larger.
69importkilla
08-05-2012, 04:21 PM
Gotta check again, tomorrow at work. I'll let you know.
Curious, whats the theory behind the actual head size?
08-06-2012, 04:29 PM
Look at the under head seat area of a 7/16" bolt with 5/8" head. It's .060" wide. Under use it will embed into the cast iron carrier & come loose, Locktite won't help. Larger head has more seating surface, or use a hardened steel washer, but be careful about bolt length if the washer is thick.
