sellersrodshop
07-05-2012, 08:26 PM
hello everyone, have a real headscratcher here. i just built a complete brake system on my 69 mustang & cant seem to get a good pedal feel. all the brake action is on the lower third of the pedal travel.
the system;
rebuilt bendix booster correct for the 69
2000 mustang v6 master with 1" bore
12.5" front disc setup from 2008 mustang gt
11.3" lincoln mark VII rear disc setup
wilwood distribution block with built in prop valve.
all new stainless hardlines, braided stainless flex lines up front & new rubber hoses in rear
the master was bench bled & the booster to master pushrod adjusted to fit the m/c bore before installing. the rear calipers with the screw in pistons were adjusted before installation to the ford/lincoln tech manual & seem to be correct as the internal parking brakes work fine. the system was gravity bledfirst, them vacuum bled with a mityvac & after that coventionally bled with the old foot to pedal method. calipers are all mounted correctly with the bleeders at the top & i get NO air bubbles when bleeding. i even opened up the prop valve to full pressure while bleeding to make sure that wasn't causing a problem, then readjusted valve afterwards. car seems to stop fine, but havent done much yet but a couple test runs around the block to bed the pads.
anyone have any ideas what i've missed or why i have no/soft pedal until its pushed 2/3 of the way down?
the system;
