View Full Version : RideTech Triangulated 4 link, upper bars?
I'm building a rear suspension system for a 1963 AMC Rambler, Triangulated 4 link, watts link and sway bar, I'm using the RideTech universal triangulated 4 link kit and I know the kits upper bars are shown going outward towards the frame, but I see the Air bar kit, and prodigy bars upper links come from the axle towards the center of the car (I have no packaging issues so either direction will fit under the car) any suggestions? on an ideal direction?
towards the outside frame rails?
61608
towards the differential center line?
61611
marolf101x
07-05-2012, 03:27 AM
The upper and lower images are how we build the majority of our AirBars (upper arm links to center of rear). This is also how the OE A-Body mounts are aligned as well.
(One note, image #1 will not work as the frame side upper mount is 90 degrees off. If you install it like this it will not move much before something breaks.)
The middle image is our AirBar for the Dodge B and E Bodies. Arms are different for clearance purposes.
I would suggest you model yours off the GM A-Body architecture or our F-Body AirBar as we have a TON of development time in those units and the results keep speaking for themselves.
Also, you do not need a lateral locating link when using a triangulated 4-link. The
Gitter Dun
07-05-2012, 06:54 AM
I was going to say the same thing. Lateral locating device not required with triangulated four link. Set the axle in the car for ride height and then set yourself up for upper links and link attatchment. This would be easiest on a frame table so that you could square and plumb all dimensions acurately but I'm sure you already knew that.
I do know that i don't need a lateral locator on a triangulated 4 link, maybe I have it all wrong, that's why I'm just asking around. So in theory because of the design a triangulated 4 link doesn't need the watts, but I was thinking that a watts will lessen the bind on the 4 link and reduce some of the slight wander that I have felt on some other 4 link designs (i have felt the same wander on leaf spring cars also and have elevated the motion with the watts)
Thanks Guys the input is greatly wanted!!! keep it coming!!
exwestracer
07-05-2012, 02:37 PM
My own opinion is that the upper links should meet at the axle, and be mounted as close together as possible. The convergence point of the upper links is the location of the roll center, and the further the links are spread apart, the higher and further behind the axle the roll center falls. Reversing the links places the roll center somewhere up around the middle of the car. This will cause some slight lateral movement of the axle housing in roll.
MIKE67
07-06-2012, 08:53 AM
Ray, the Milliken's define the upper link convergent point as "lateral restraint point". The roll axis is a line thru that point and parallel to the side view lower arms (for parallel lower arms). The roll center is where the roll axis crosses the rear axle vertical plane. The problem is that the roll axis moves with the lower arms and to have some roll understeer the lower arms must slope down to the front of the car. This puts the instant center very low.
Having the upper arms converge at the frame mounting ends can result in some weird roll center positions depending on their side view angle.
this getting awesome!!! :worship: this is what I want, give me more guys, digging the info
exwestracer
07-06-2012, 05:16 PM
Thanks, Larry. I was thinking solely about the links converging at the axle. Shouldn't be posting from work anyway! LOL
Gitter Dun
07-06-2012, 05:43 PM
What would be optimum horizontal angle for the upper arms? length? Length compared to lowers?
MIKE67
07-07-2012, 02:29 PM
WOW! Now that is getting to the heart of the matter. Simple answer, it depends. It depends on what compromises you are willing to make. It depends on available room to package the suspension (or how much fabrication you are willing to do), how much anti squat you want, how much pinion angle change you can live with, what is the side view angle of the lower arms, how much rear roll steer you want and what rear roll center height you want. All of these affect each other, so there are thousands of workable combinations. If it was easy, anyone could do this stuff.
exwestracer
07-07-2012, 05:13 PM
Upper link length is usually a packaging issue, as Larry pointed out. the "sweet spot" seems to be about 70-75% of lower link length, as measured in side view. This is the "effective length", not the actual length of the bars themselves.
Gitter Dun
07-07-2012, 09:51 PM
Thanks guys....no intention on building one.....just have a great interest in suspension technology. I think ultimately....if I was to try and put something together it would run more down the lines of a 3 link with watts set up. My current set up is leaf spring with Fays 2 watts. Amazing what rear roll center height adjustment does for the front handling of the car.
https://static1.pt-content.com/images/pt/2011/03/WattsLink101-1.jpg
https://static1.pt-content.com/images/pt/2011/03/WattsLink100-1.jpg
https://static1.pt-content.com/images/pt/2011/03/WattsLink099-1.jpg
https://static1.pt-content.com/images/pt/2011/03/WattsLink098-1.jpg
https://static1.pt-content.com/images/pt/2011/03/WattsLink096-1.jpg
MIKE67
07-08-2012, 04:38 PM
I agree with the roll center adjustability. That is a problem with the 4-Link. It also usually has a high roll center. But, it is simple and usually easier to package.
Great Question Gaetano!!! like I said I love the info and I have no packaging issues building this car so if the upper links or link needs to protrude into the cabin floor so be it, it is a wagon!! so heres what I understand right now
1) lower arms must slope down to the front of the car
2) upper arms about 70-75% of lower link(arms)
3) angle of upper arms?
so are many here thinking a 3 link as opposed to a 4 link?
Gitter Dun
07-09-2012, 06:34 PM
If it was me, I would do a 3 link with a watts. Rear roll center adjustability is something that I have just begun to do and like I said, it is amazing how rear roll center adjustment works in balancing the handling characteristics of the car. I have knocked a total of 4 seconds off my lap times at T-Hill with bypass config. just from adjusting rear roll center height. Got down to 2:04's in two track days and I'm not done tuning. I should be able to get in the 2:00 range on 100 tread wear tires.
ok ok ok so I should lean towards the 3 link, next tough question for everyone!!
centered 3 link or offset 3 link
61879
AMC Racer
07-10-2012, 08:29 AM
Have you considered a torque arm?
feeble
07-10-2012, 08:59 AM
If you have to build it anyway, I would use the offset link.
I had thought about it....but? I have havnt had any chances to see one at the tracks in action, never rode in or drove one so that was one of the reasons I wasnt looking at those, I have rode in Kyles DSE car with there 4 link, rode in Mary and Deannas Hotchkis 3 linked car, Bretts new 68 Camaro(west coast version) ride tech car felt and looks smooth at the events with there triangulated 4 link, so Ive leaned towards the linked rears for the wagon project
AMC Racer
07-10-2012, 01:53 PM
Torque arm seems a simpler way to go and was used stock in the later Camaro, etc. ... but if you're up for making the structure for the upper link and want the adjustability, a 3-link works. Control Freaks makes some Rambler / AMC stuff including a triangulated 4-link .... but if you're making parts yourself, likely can make something to suit for less $$ and get some adjustability.
http://www.freakride.com/2011_amc_suspension.pdf
Gitter Dun
07-11-2012, 12:43 PM
Why offset link?
Why offset link?
yea, What he^^^^^said?
feeble
07-12-2012, 06:01 PM
Most of what I have read indicates that an offset upper 3rd link helps equalize rear tire loading under acceleration.
I just figured that it was a packaging issue and that's why its offset (easier to put a longer upper rod off to the side and keep it lower than the center drive-shaft hump and over the differential) any threads or data around the equalization theory, and how do we determine location for that link?
Great stuff guys lets keep going
MIKE67
07-13-2012, 09:33 AM
Rod, take a look at Bill Shope's tech pages for a three link calculator. He is dealing mostly with drag racing but it is applicable to this discussion. He has lots of good info on other suspension layouts so take a look around.
http://www.shopeshop.org/tim.19.htm
Bryce
07-17-2012, 09:38 PM
61879
Centered 3-link with a chassis mounted watts pivot. At least that is what I did.
thanks for jumping in Bryce I need all the suggestions i can get
Gitter Dun
07-19-2012, 10:14 AM
I agree. I would prefer to center link on top of diff. Although obviously there will be some packaging issues it certainly can be done. I'm thinking I if it were me I'd run some DSE style subframe connectors and tie front of the link into a fabbed cross member that welded into the subframe connectors and sheetmetal.
:pat: shhhh!! keep it down Gae
if my girlfriend see's youre idea I will be fabbing that idea also...its her car!!
thats actually a sweet idea I was going to bridge the center link/links to the frame to add support, Im still trying to decide the tops, the bottom is almost done! and the watts is almost done
fishn4four
01-06-2016, 06:42 PM
I love forums! It never ceases to amaze me the talent and knowledge of the people on this forum! So first off...Thank you! All of you!
I recently purchased a 1970 Trans am that has been setup for pro street. The rear suspension is a ford 9" with traction bars welded to the rear end and coil over shocks. It was setup for drag racing and now I want to convert it to handle the curves. After reading through several threads about suspension setups, I think the easiest/cheapest and BEST performing solution would be to convert my ladder bar setup into a 3 link or maybe torque arm. Here is what I was thinking and you guys tell me if you think it will work.
Cut the ladder bars apart and use just the lower part, removing the forward and rear heim joints and replace them with Johnny joints or the bushing type connectors.
Next weld a cross brace in between frame rails and a bracket to the top of the 9" to connect the "3rd link" from the rear axle to the car. (Should that connection use heim joints on both ends?) or order the universal torque arm from chassis works and mount it below the differential?
Last... install watts link and sway bar to control roll.
121852121851
What do you guys think about the existing mounting points of the ladder bars? That should work right?
