View Full Version : Power Steerng Sensitivity
69importkilla
07-04-2012, 02:58 PM
My 69 has the original PS box, and the pump is from a 04 Gm truck. Is there anyway to make the steering less sensitive without replacing the steering box itself?
12sec ss
07-04-2012, 04:11 PM
i know when i did LS swap in my RX7 i had to take return spring out from under the high pressure fitting and cut about 1/4" off of it to lower the pressure to Mazda rack, maybe same principle applies?
07-04-2012, 05:15 PM
trucks generally ran higher pressure valves around 1400 psi. stock was 850 to 900 on a first gen Camaro. None of the stock first gen boxes have a very good feel to them. Any third gen Camaro box would be much much better. The IROC box is WAY better.
69importkilla
07-05-2012, 03:44 AM
Ok, thanks! Next would be, what kind of undertaking is it to install the IROC box?
SLO_Z28
07-05-2012, 03:59 AM
The only part that isnt a direct bolt in is the lines are metric, and yours are SAE. You can either get fitting adapters for sae>Metric, or just get the 3rd gen pump and lines and have a whole new system. Another option that is only a little more expensive but a direct bolt in is the AGR steering box, great feel, faster steering without being touchy, and they're only about $360.
ProTouring442
07-05-2012, 07:34 AM
The amount of assist in a power steering gearbox is governed by the torsion bar connected to the spool valve. Lowering the PS pump output pressure simply lowers the maximum assist, which can lead to a dangerous situation! Thus, you must replace the box for one with a thicker torsion bar/spool valve combination.
If I recall correctly, increasing caster will, up to a point, increase road feel. So a combination of a new box (one of the new hi-tech boxes would be great), and an increase in caster may give you what you seek.
Shiny Side Up!
Bill
07-05-2012, 07:24 PM
The AGR box is a bolt-in.
69importkilla
07-06-2012, 03:22 AM
I appreciate the suggestion of the AGR box. I'd prefer to go with Dave's original suggestion of the IROC box ( Its on the cheap! Bonus! ) at least for now. I got the comments on the metric hose, luckily I still have the original metric fittings for the truck box ( hopefully they are the same ). The other question I have, is the original ( original to 69, not the actual original ) rag joint going to work?
07-06-2012, 07:03 AM
no, you need 0ne from a 79 camaro, or Lee Manufacturing has them.
Skip Fix
07-08-2012, 09:01 AM
Lee also has some tap in adapters for the O ring fittings to use flare. The thread for the metric on the box -standard are close enough often also to use the stock lines.
