H2Ogbodies
06-27-2012, 07:05 PM
I have a lot of electric fans in stock and need to move some duplicates-if anybody is interested I have 6 Rf24 fans (little brother to the Mark VIII) with dual speed relay harnesses for each fan-the fans are used but have been tested and the dual speed rleays are rated @ 60 amps and they too have been tested and work as designed-very simple plug n play deal-two ground referenced trigger leads switch bewteen low and high speed on the fans. The RF24 fans are dual speed and are rated @ 3800-4400 CFM. dimensions are identical to the Mark VIII fans.
Asking $200 for each setup-I've tested each for operation and they are ready to go-email or PM with an email for pics. [email protected] Thanks!
I've had several requests for a pic so here is one of the fans-cleaned, tested and pre-wired. Included is a dual fuse holder for each speed-30a for low and 50a for high. The secondary relay is for AC trigger or manual over-ride. There's a total of only 6 wires to run and two of them are grounds-doesn't get much easier than that!
https://static1.pt-content.com/images/pt/2012/06/1340932354-1.jpg
