View Full Version : Lets Talk Brake Kits
pharmd
06-24-2012, 02:46 PM
So I have a full weight 02 Camaro currently with stock brakes. I am shopping an upgrade on the fronts (for now) as most folks comment that the rears are totally adequate with the proper pad. I have access to preferential pricing on GM products thru a dealer friend, and I am a reseller of Wilwood brakes. Obviously I want better braking. The car will likely be 50% autox, 30% road course and 20% street (but during parts of the year those could change). So I need a well rounded braking setup, and Pad selection will be key. I don't want to run dedicated race pads, autox pads, and street pads, as I don't have time to be swapping pads all the time with work and remodeling our house. Im not saying cost is not an option, because it is, but I'm willing to pay a little more for the aftermarkets if they are worth it.
I called Wilwood last week and discussed my situation...the guy I talked to suggested Forged Narrow Superlite 6R Big Brake Front Brake Kit (Hat) (http://www.wilwood.com/BrakeKits/BrakeKitsProdFront.aspx?itemno=140-9834&year=2002&make=Chevrolet&model=Camaro&option=) over the Superlite 6R Big Brake Front Brake Kit (Race) (http://www.wilwood.com/BrakeKits/BrakeKitsProdFront.aspx?itemno=140-7190&year=2002&make=Chevrolet&model=Camaro&option=). They said the pad on the race brake wouldn't work well (not rotor friendly) for the street. BUT pads can be swapped right? They recommended their BP-20 pad for my specific needs.
Obviously the other good option is a C6 base or Z06 kit. I could purchase track brackets, buy the parts thru the discounted dealer and be out the door fairly affordably I suppose. This kit probably doesn't have the asthetics of the other kit.
So if you guys were me, which front brake kit would you go with? What reports or history do we have on the Wilwoods? What front/rear pads should I plan on running?
Thanks for any and all assistance!
SLO_Z28
06-24-2012, 03:53 PM
What is wrong with your current brakes that you want to replace them? The LS1 brakes with the right pads are more than sufficient for track use. The wilwood kits are a waste of money and too heavy, they have less clamping force than the stock calipers. Your current calipers are equivalent to a C5Z06, and C6 setup, I wouldn't even look at Brembo as they make garbage IMO. The 99-07 trucks have a better caliper than any of the corvettes and there are people making kits to adapt those now, so thats an option. Another option is a company called "The Brake Man", they make a F4 Tornado caliper setup that has more clamping force of the stock brakes, is much stronger than anything than wilwood or baer makes, and it releases quicker. The low drag pistons on the Brake Man calipers are something that no other caliper matches, and is something you can really feel, it is the equivalent of a 40hp drag on a standard caliper, and it weighs less.
What would I do if I were you? Put some Hawk HP+ pads in, and get some decent 2 piece rotors with the stock setup.
jpgolf14
06-24-2012, 05:02 PM
There is no way the OEM brakes will work on the road course without high temp pads. The OP said he doesn't want to be switching pads all the time. That means finding a setup that is overkill enough to work on the road course with street pads. That is some pretty serious overkill on a heavy 4th gen with a log of power. My suggestion would be to take a look at the Gen 2 CTS-V Brembos. They have a huge 14.66" x 1.33" rotor, high volume pads, and a large caliper. All of those features will help keep the pad temperatures down on the road course.
Don't be fooled by claims of "higher braking force". All that really means is that the calipers have larger piston area. Braking force doesn't really matter at all. What matters is braking torque. Brake torque is force * moment arm. The moment arm being the distance from the center of the rotor to roughly the center of the pad. The downside to larger piston area is that you will have a longer pedal with lower effort. It is a tradeoff. The beauty of the larger rotor is you get more brake torque for "free". In other words, it stops the car better without making the pedal longer. Further is looks like the Brake Man calipers are available in many piston sizes from less to more area than the stock calipers.
I also question the use of low drag pistons. Typically that results in the piston being retracted to far when you take your foot off the brake. That means next time the pedal will be longer as the pad has to travel further to contact the rotor. Do you have any tech info those calipers? How do they accomplish low drag?
John
pharmd
06-24-2012, 05:22 PM
Most folks the do any serious racing have upgraded over stock. Stock maybe fine upgrading a 1st or 2nd gen for heavy street use, but these cars weigh close to 4K with full tank and 1 passenger. Most guys on FFRAX have gone c6, CTSV or aftermarket. Like I said, I am a reseller of Wilwood, so it wouldn't be bad to run what you sell. But since its a shop car, testing many different options isn't a pad plan either. Asthetics of a nicer caliper isn't a bad thing either. Additionally I understand that pads for aftermarket calipers are lower cost than stockers also.
SLO_Z28
06-24-2012, 05:29 PM
With the right pad compound you can accomplish a .48μ from 70 degrees to about 1000, while this is short of the .59-.65μ that race pads will have at heat it is more than enough to overwhelm street tires. I would argue that the additional weight and MUCH higher polar moment of inertia of the big brakes is much more detrimental than any gains seen from the additional lever arm on the kits were talking about.
There are a number of good papers that talk about how he accomplishes what he does with the calipers, are you a member of the SAE?
pharmd
06-24-2012, 06:58 PM
I guess my question would be...then why would ANYONE run Baer, Brembo, Alcon, Stoptech, Wilwood etc...if stock is fine with a pad change...IMHO that is crazy. Is the stock setup an economical one, absolutely, but dispite the breadth of technical knowledge you have provided, I would have a hard time believing that C6, or CTSV or aftermarket setups arent more formidable. I have spoken with the editors of GMHTP about their "sti killer" build. They have had stock ls1 brakes, Baer 6 piston, CTSV, and 5th gen camaro rotors with C6 zo6 calipers...so far the latter has been their favorite setup....so IDK how stock can be adequate?
jpgolf14
06-24-2012, 08:03 PM
What pad are you referring to? Have a coefficient of friction / temperature chart handy? I always worry about the borderline street/track pads. I am a stickler for quiet brakes. Nothing worse than a well thought out car with squeaky brakes.
I have run Wilwood BP 10 pads in the past that have been really good over 700 degrees but never had them above 800. 1000 seems pretty extreme for a street pad. This was on a lighter weight 3rd gen with only 300rwhp / 400rwtq on a 13" x 1.1" rotor. I would have to imagine with a smaller rotor, more weight, and more horse power, the OP will not be able to use a street pad.
The additional mass and radius always buys better braking. Sure there are other downsides like higher un-sprung and rotational weight. Everything in a car is a compromise. Most of us on here are not all out racers, including myself. For me overkill on brakes is worth the weight. Hitting the margins just right is fine for racers. Of course racers wouldn't be running street pads either.
Regarding SAE, no I am not a member, I am an aircraft guy, cars are my hobby. A paragraph paraphrasing the technology would be fine.
pharmd
06-25-2012, 04:06 AM
Car will make around 500rwhp when all said and done, car has a few lightened pieces, but is still likely going to be heavy. Would the BP 20 pad be a good compromise (street/track) considering the power/weight of the car? That was the recommendation of Wilwood.
jpgolf14
06-25-2012, 06:12 AM
The BP-20 will probably work ok. It is advertised to over 900 degrees. They might be a bit soft the first stop or two in the morning. My BP-10's were soft until they got a tiny bit of heat into them. I'm sure the 20's will be worse. I also don't know about noise. The BP-10's are quiet and moderatley dusty.
I would run the biggest rotor possible. Something like a 14"x1.25" in order to keep temperature out of the pads. With this combo I'd say there is a pretty decent chance you can run street pads on the road course.
What caliper are you thinking about, the SLR6? I ran the 4 piston version, the FSL. I liked them alot. Another option would be to run one of their big calipers like the W6A which will keep heat out of the pads even better.
I would still take a look at the CTS-V brakes though. They really aren't that costly. And they work really well on the 4200lb, 556HP CTS-V.
pharmd
06-25-2012, 10:14 AM
Wilwood Road Race brakes (http://www.wilwood.com/BrakeKits/BrakeKitsProdFront.aspx?itemno=140-7190&year=2002&make=Chevrolet&model=Camaro&option=), these are the ones I think would probably be considered their highest performance setup...but the tech guy suggested I run the
Wilwood SL6R (http://www.wilwood.com/BrakeKits/BrakeKitsProdFront.aspx?itemno=140-9834&year=2002&make=Chevrolet&model=Camaro&option=)...he said simply because the pad choice on the race setup was too harsh for daily driving. Well can't the pads we changed??? I want the best setup I can run (best durability/longevity/performance) within this price range. I am considering the CTSV and Gen 5 camaro brakes, but they all require modifications and I don't want to get into a situation where the car is held up from getting back on the road because we are having to fabricate or wait for parts. I know those are quality brake setups though.
jpgolf14
06-25-2012, 10:30 AM
Those SL6's are a nice midsized caliper. They are by no means the best Wilwood makes. The W6A is their common big caliper. Those are the calipers typically used on the modern Vette kits. And the Integra is just plain stupid.
On a fourth gen, the swap to the Gen II CTS-V looks like its really easy. Check this link.
http://www.gmhightechperformance.com/tech/brakes/1011gmhtp_cadillac_cts_v_brembo_brakes_nitto_tires _wheels/viewall.html
pharmd
06-25-2012, 04:12 PM
Yeah, I talked with GMHTP about the brake issue...they said their current setup of gen 5 camaro calipers with CTS-V rotors (or C6Z rotors, can't remember) was probably their best setup, but they were going to have to swap to a 3rd Gen master cylinder because the stocker wasn't up to the challenge. I just hate to have to modify fabricate etc a bunch of stuff to retrofit. When you factor what the GM parts cost, then labor, then a new master cylinder...and not really knowing how they will perform (GMHTP has had issues with rear brake bias) do you need a proportioning valve or not...it all makes my head spin, and I'd be willing to pay a little more for the Wilwoods and call it a day...But I see what you are saying, the W6A is their premier Caliper...I wonder if that Vette kit would work on the fbody? My wheels are 18" Forgestar CF5's, and they are clearanced for big brake kits.
Jay@GMR
06-26-2012, 02:59 PM
Here is some good reading...... http://www.thebrakeman.com/pbr_vs__tbm
Here is an option..... http://www.thebrakeman.com/camaro_82_02
The GMR is a "Brake Man" dealer should this be a direction you want to go?
Regards, Jay
jpgolf14
06-26-2012, 04:01 PM
Regards, Jay
Thanks for the links. I was looking for some real technical content though.
Honestly, I have never used the Brake Man products or the OEM PBR's. But I have to say, is that site for real?
"All caliper manufacturers claim they have what it takes to compete with us, unfortunately they don't. "
Really? I have NEVER seen another company say anything about The Brake Man.
In fact, most of the calipers being "hyped" with big dollars in full page ads are totally inadequate in a true racing atmosphere. A good example is seen below. This is a PBR caliper, commonly used on both Corvettes and Mustangs. It is also the caliper that a competitor uses in their "performance" kits. As you can see, this is anything but performance.
Again I have never seen anyone claim the plain jane two piston PBR is a "performance" or "race" caliper. In fact I have NEVER seen an advertisement from PBR. So I'm not really sure what they are talking about. The limits of the OEM PBR's are well understood.
Keep in mind that there is a 40 horsepower brake drag savings by converting to The Brake Man!
HUH? How do they figure that? Anyone ever jack up their car and spin a front wheel by hand? Do they really think the little bit of drag is costing 40hp? Can you image the difference in gas mileage removing a 40hp brake from your car would net? I wonder why the OEM's haven't done this yet? I would like more explanation on this.
I can't really understand why they chose to pick on the 4th gen / C5 / C6 / Mustang STOCK caliper. Those front only kits are $2400. They better perform better. Why don't they compare their stuff to Wilwood FSL, W6A, Brembo GT, CTS-V, PBR Z06, etc... ?
Their stuff may be the best ever. But I am highly skeptical solely based on the fact they compare their stuff to 15yr old OEM stuff. I just checked the price of 2 front PBR calipers and 2 front rotors for a 2000 Corvette, total is about $250.
So lets make this a good discussion. I really don't have any doubt "The Brake Man's" kits are better than stock. But lets gets some good discussion going.
How do they compare to 2009+ CTS-V calipers? Since that is probably the best "easy" swap for a 4th gen. Cost of CTS-V front rotors and calipers is ~$1000. Figure another $500 for pads, lines, brackets.
Jay, I believe you are a dealer for the Z06 calipers as well. I understand if you would prefer not to comment, but how do you feel about the Z06 vs Brake Man calipers?
Finally, the OP is interested in a setup that will allow him to drive street, auto-x, road course without changing pads. I am just not sure if the 12/13" x 1.25" rotors on The Brake Man kits are going to get that done.
Sorry for being blunt. I just want to make sure we talk about facts, not marketing.
John
jpgolf14
06-26-2012, 04:03 PM
Brake balance will likely be an issue with any kit unless you match the total brake torque ratio front to rear to stock. One nice solution is an adjustable proportioning valve.
The GMR
06-26-2012, 05:16 PM
Here are a few other links to writings by the founder of Brake Man, Warren. He can be a little abrasive with his writings, but his content is real. There is some real life independent testing done by a Nascar Team that should be posted soon I believe. Either way, He has more then what I'm linking to, but this is all the important info on his site.
http://thebrakeman.com/articles
Yes, Warren has been involved with the higest levels of racing for longer then I have been alive. He is also the gentleman who holds multiple patents that not only the brake man uses but from what I understand maybe a few other "large" manufactures. From Calipers to Rotors, Warren has the patents / results to back up his statements. So take what he says for whats it's worth.
His products have a place, but not with everyone and even I understand that.
They have on many occasions, the results turned out to produce about 30% more clamping force from the F4 caliper then a high end AP counterpart, and that was at ambient temp (not race temp). The true strength of the Brake Man components are seen at race temperature, where the standard monobloc will loose strength while the Brake Man calipers actually increase in strength with approaching 400deg.
Sorry I do not have any direct hands on knowledge of the CTS-V calipers so I will not be commenting on any comparison.
Great Question, but I do not classify them in the same field. The OEM Z06 calipers are a great monobloc caliper for the price, arguably the best "bang for the buck" monobloc on the market. For those that really do appreciate the corvette OEM style products I really cant suggest a better caliper other then the Brembo Ceramic packages from the ZR-1. For the "hardcore" applications I will suggest Brake Man, in fact we are working on a package for the pro-touring / road race / drag race market that will be revealed for SEMA.
Well, the rotor size really is not the issue. I honestly prefer smaller rotors for the race applications, the way I see it, larger is only more rotational mass. Now, for a pro-touring car where the style of the 14 inch rotors is unmatched, I strongly suggest going with equal size rotors front to back. The reality is that depending on how the setup is designed as a whole the overall goal of stopping the car properly will not be an issue. I personally love the look of the large 14 rotors with the PBR monobloc calipers, great performance and the style I prefer. Project BB is running a rear 12.19 by .810 rotor and the owner has reported that since we upgraded the rear end the brake issues were solved.
No problem, its all in good fun and this is what forums are for!
John
thanks
Jason
jpgolf14
06-26-2012, 06:04 PM
Sounds good. I'm not surprised Warren knows what he is talking about. I'm just not crazy about his approach.
Regarding the clamping force. That is solely based on hydraulic advantage. In other words, how much piston area the caliper has. All the manufacturers make calipers with different sized pistons.
Example Wilwood FSL caliper. It is available in the following piston configurations.
1.88 / 1.75
1.75 / 1.75
1.62 / 1.62
1.38 / 1.38
1.25 / 1.25
1.12 / 1.12
It is up to the buyer to make sure their system is matched. The problem with big piston area is that is also increases the pedal travel. So it all depends on the whole system and driver preference. Do you want you brakes to be: high effort/short pedal (ie small caliper pistons) or low effort/long pedal (ie large caliper pistons)? The answer is typically somewhere in the middle. That is the beauty of large diameter rotors. You get better brake torque without the downside of the longer pedal. Basically free brake gain. Of course the downside is more rotational and sprung weight. Of course another upside is a larger rotor has more thermal mass, keeping the temperature of the whole system down. This will help keep "street" pads in their temperature range.
I agree, in a race car, run the smallest rotors you can get away with. With the proper pad, run the brakes at 1000+ degrees.
John
pharmd
06-26-2012, 07:20 PM
So that still leaves me undecided...Looks like to me the WA6R Wilwood Caliper with the 14" rotor would be probably the best setup (from a compromise of asthetics and Performance). Problem is, that is a Vette kit, not Fbody...Could it be retrofit to the Camaro? Otherwise the best Wilwood has to offer is the Billet superlite 6R caliper with the 13" caliper (the race kit). Personally, those brakeman kits may be awesome, but they don't have the "look" that I am after...it has to be a compromise between performance and looks....this isn't a purpose built racecar, this is a pro-touring style setup, that I want to take on the powertour, run Pro-touring events, and do some track days, along with drive to work occationally. I understand I am going to give up some over a pure race setup...at the same time, the car itself, is giving up some to dedicated 4th gen race cars (about 500lb to be exact). So to me the decision really probably boils down to a Wilwood Kit, or the CTS-V caliper (which rotor is the one to pair with this), or pony up and buy a more expensive aftermarket kit. I am open to anything at this point...I'm virtually about to have an aneurysm over this stuff. I got the motor decided on and being built, suspension and ancillary parts are ready to go, I even have the seats picked out...The brakes...oh, the brakes (my head hurts)!
Jay@GMR
06-26-2012, 07:41 PM
Regarding the clamping force. That is solely based on hydraulic advantage. In other words, how much piston area the caliper has. All the manufacturers make calipers with different sized pistons. Not so, you must also take into account caliper body flex as a MAJOR variable....in an apple to apple comparison (piston size/area), most all competitors calipers will flex (and alot), and will lose much clamping force in comparison to the Brake Man design. So you will see....although others can offer the same piston sizes/area, they cannot offer the level of rigidity the Brake Man caliper body does.
Since you have chosen the below listed FSL (Forged SuperLite) as your comparison....have you ever actually watched one as it clamps down on a rotor? I have, and is why we recommend the Brake Man calipers as a more serious choice. Dont get me wrong, we are a Wilwood dealer as well and sell Wilwood calipers as well, but just figured we would make this recommendation to the original poster as an "option" and was not meant to get you excited. If you have chosen your path for calipers that is fine, but the OP has not.
1.88 / 1.75
1.75 / 1.75
1.62 / 1.62
1.38 / 1.38
1.25 / 1.25
1.12 / 1.12
John
Thanks, Jay
Jay@GMR
06-26-2012, 07:51 PM
I can appreciate the "looks" as a major factor and agree the Brake Man calipers are not as SEXY :naughty: as some of the others that you are considering! Well good luck on your brake decision and hope I did not offend by the recommendation. :cheers:
pharmd
06-27-2012, 03:58 AM
Absolutely not....And I will stay tuned for the new Pro-touring brake system that the Brakeman is releasing at SEMA.
jpgolf14
06-27-2012, 08:17 AM
Thanks, Jay
Jay, like you I'm just trying to provide options. I picked the FSL for comparison becasue they are very common on aftermarket kits. I have used them in the past and they are a fine caliper. I have since stepped up to the larger body calipers, entirely for looks, how dumb is that. The Wilwoods were adequate for my stopping needs.
You are correct, caliper flex is a factor and will kill some of the clamping force. I question how much difference you are going to see between a Wilwood, Brembo, Brake Man, Alcon, AP fixed caliper. All of these designs use steel bridge bolts to stiffen the caliper. I have never seen actual flex comparisons. But would be intersted in seeing data if you have it.
I will say that a quality 1 piece caliper is much more expensive than a quality 2 piece caliper. So I applaud The Brake Man for using a two piece design. It is much easier to stiffen the caliper with steel bolts than more aluminum.
Finally I look at the OP's requirements.
A brake kit that can be used on his 4th gen for street, auto-x, and road course. Nowhere do I see a requirement for the stiffest caliper ever made. I'm just trying to suggest kits that meet that requirement. Its all to easy to lose track of what makes a car better "for the driver". We are all guilty of that. I once spent $300 on fabric covers for my hoses. Looks cool but doesn't make the car drive any better.
ace_xp2
06-27-2012, 12:00 PM
Has the Brake Man ever revealed what alloy he's using for those calipers? He claims it's 50% stiffer than any standard billet aluminum piece. But that puts the strength of the material well into the metal matrix composite range, at which point his prices are about a factor of 10 lower than they should be.
And I still wonder how good they could be at torque stiffness, there isn't much bridge there, so I can't see how it could be as stiff as wider bridge design when the rotor is trying to take the outboard pad along for the ride.
When it comes to caliper selection, another thing to consider is the price of pads. I was planning on going with a set of z06 calipers until I read on CorvetteForums that a set of CSR pads run $300 for the front, and that a set of H compounds in a wilwood Super light caliper was only $200 and would last nearly twice as long. Combined with no one having any complaints about the brake feel it seems like a better way to go.
Corvette forum link:
http://forums.corvetteforum.com/c6-z06-discussion/2970608-c6-zo6-calipers-good-bad.html
jpgolf14
06-27-2012, 12:39 PM
Yes the Wilwood pads are pretty inexpensive and have a lot of volume. The standard issue BP-10 compound in the FSL size (pad size 7420) is about $80. I have also purchased Hawk Ceramic ($90), Wilwood Q compound (~$120 IIRC) and Poly B (~$150 IIRC).
Yeah, there really is no magic to aluminum. It is hard to believe his material is any better than what the others are using. It is also impossible for the AL to gain strength with temperature.
The GMR
06-27-2012, 05:04 PM
Brake Man Calipers utilize an interlocking dual internal crossover tube / bridge system that is made from a multiple heat / cryo stage high carbon material. I do know exactly what it is and how it is done but I will not disclose that because I believe warren told me in confidence. This is where the increase in strength and drastic reduction in deflection occurs when at non-ambient temperatures approaching 400deg.
To take that a step further, he is also using a very specific AL material for the sides (bodies) of the pistons, this material is also multi stage forged to ensure that the grain structure of the material is placed accordingly to complement the design of the caliper. Again, I know what it is but I will not disclose it, to my knowledge no other manufacture is utilizing it.
I can literally go on for days, Brake Man has done something VERY different then All other manufactures I have found.... problem is that He also owns the patents to these benefiting differences, hence why you do not see this style caliper more often.
Like I have said, Every caliper has its place. Here is a picture of an SL that is actually doing very good according to the owner. This car just placed 1st and 2nd at a recent event as well. This is a perfect example of a Wilwood SL getting the job done on a Drilled/Slotted 12.19 by .810 rotor. If this is getting the job done then its fair to assume that a 14 inch with the 4 piston Z06 calipers will work better when the relative matching front balance is in place!
TheGMR.com has a variety of offerings because we are NOT in the business of manufacturing brakes... Hence Why we cater to all manufactures across the board from BAER, Brembo, OEM/PBR, Wilwood, and Brake Man.
The GMR
06-27-2012, 05:11 PM
Sorry guys, I'm not trying to be abrasive. I'm simply busy and wanted to clear a few things up.
Carry on!
Jason
pharmd
06-27-2012, 06:58 PM
Carry on!
Jason
So is their a 14" quality rotor, that can be used with the Wilwood 6piston fbody caliper? The kit I am looking at has the thermlock piston 6 piston caliper but only has 12.88" calipers (due to the race series rotor size limitation in the series it was designed for). I would like to run this setup but with a larger caliper (both for heat dissapation and looks). Something that is the lightest weight of the race durable rotors. with brake cooling ducts, and large rotors, I hope to be able to run a less aggressive pad that I can run on the street, yet will survive some hot laps. Does anyone have suggestions on pads that will work with this wilwood caliper (the BP-20 is what Wilwood recommended), then the ferodo ds2500 is what strano recommended, I know alot of guys run carbotech...Any suggestions?
Jay@GMR
06-27-2012, 08:17 PM
I see no reason why you could not run Wilwoods very common 14"x1.25" GT rotor in place of the supplied 12.88" with the SL6R caliper kit if this is the caliper you feel you need. The caliper bracket supplied with the SL6R race kit is the same dimension as the FNSL6R 14" kit. You will just need to utilize a spacer (usually supplied with the radial mount bracket) on the 2 mounting studs to raise the caliper up to sit correctly on the rotor. Let me know if you need us to quote you on this setup and I will contact our Wilwood rep to sort out your particular needs and get you a price.
Another suggestion would be to just purchase the FNSL6R 14" kit (only lacking the Thermlock Pistons) and run it. Assuming this is more for the street with an occasional track appearance, you may benefit from the standard stainless pistons with dust boots that the FNSL6R's utilize? The SL6R "race" kit is nice if you really need the thermlock pistons, but you do lose the dust boot that does help in street applications. Just something to think about.
Regards, Jay
ace_xp2
06-27-2012, 08:23 PM
Hey, don't be silly, you're not being abrasive. I've simply a boundless curiosity for these things and a need to know what makes things better.
You don't have to disclose the design of the crossover tube, it's in patent 5515948 (http://www.patentgenius.com/patent/5515948.html).So it's steel bridging then, and the the two steel tubes at either end are hollow and held by a bolt on one side and then by a nut on the opposite end so as to allow the fluid to get in. I see that the claim is that the two transfer tubes increase the rate at which the fluid can get through to the opposite end of the caliper. Which is interesting, as it implies that the typical transfer tube is small enough to act a a restriction in the brake line. But I've been the victim of leaving the bleeder open before and must note that there is precious little braking force available when that is the case.
I'm guessing the pad retention/c channel bridge on either end is also made of steel. Which makes sense as I've always wondered why there were additional bolts low on the caliper. It seemed odd to make the two lower parts of the c channel units seperate entities from the main bodies when they wouldn't contribute to stressed bridge strength anyways. But then it's not the same as an bolt stressed aluminium bridge, due to the material it doesn't need to be.
The only patent I can find by him is the one previously listed though, and that doesn't cover the c channel bridge nor any metallurgical specifics. I suppose it may be defensible as it is already in the design, but I still think if there was a major advantage to that bridge it would've been copied by now.
Don't forget, racers dealt with flexy calipers for years because the advantages of a bigger rotor and a notable decrease in the ratio of sprung to unsprung weight was worth it. What I'm saying is that flex may make for a reduction in feel and an increase in pad taper, but if it comes with reduced bridge height the gain in rotor size may be worth it.
The GMR
06-27-2012, 09:08 PM
Yes the Bridges are Steel, very specific material selection along with manufacturing process.
The Cross Over Tubes, Bridge Design / implementation, and the Hurricane rotors (U.S. patent number # 5,626,211) are Three patents I know about... mainly because I was actually looking into building calipers but my machinist stumbled upon the caliper patents about a year back.
Just like most I was very skeptical when first introduced to Brake man, after spending time talking over everything with Warren, and doing my own research I concluded that he does have the knowledge to back up his statements. When I get the new items complete and pictures taken I will be sure to post. But the OP does have MANY options on the table. Most of which will work out just fine for his desired application as long as everything is setup correctly.
jason
ace_xp2
06-27-2012, 10:06 PM
It's funny, the PatentGenius website lets you click the authors name, but doesn't display his additional patents.
patent 7137488 (http://www.patentgenius.com/patent/7137488.html) is for the C channels, but I think porsche would have something to say about that:
61326
That design was on the 930 a little less than 30 years before his patent.
pharmd
06-28-2012, 04:51 AM
Regards, Jay
Yeah I would be interested in knowing is that conversion can be done..or if you could just order it with the larger caliper from the get go...saving a little extra from having to purchase 2 sets of rotors. I like the thought of thermlock, as if I get heavier into racing I will already have them. The car will make close to 500rwhp, and with the RR kmember, tubular a arms, 10 bolt, lighter seats, lighter wheels, etc, the car will be fairly light as full street fbodies go (probably closer to 3400 with full tank).
Jay@GMR
06-28-2012, 06:00 PM
Working on it! I will PM you a price soon.
Thanks, Jay
Jay@GMR
07-05-2012, 03:09 PM
PM Sent! Sorry for delay (was waiting on tech info from Wilwood) Thanks, Jay
