WS6
07-21-2005, 06:23 PM
ok i know very little about and have very little experience working on a BBC. i know they are very similar to a SBC, but i dont know their specifics. i think the problem may be BBC specific but i honestly dont know.
the engine is a 71 454. has a big cam headers and dual three inch exhaust. torker 2 intake i believe and a holley 750 at least on it. yes i know i dont know the specifics that well. this isnt my car. just one im playing with. heres the issue or issues. get the car cranked and warmed up. once it is warmed up it will start to pop in the exhaust as if the timing is way retarted and its exploding in the exhaust. to get it to stop, i advance the distibutor until it no longer does this popping. you can drive the car perfectly fine after that. no popping. no stumbling. i honestly dont nail it very hard since its a four speed and geared low. the neghborhood wouldnt like hearing this car opened up. shut it off and it does not diesel. check the plugs when its cold and they arent excessively rich or anything horrible. im sure it could use some tweaking to be right, but its not off by much.
this is the problem. go to crank it up after its cooled off and it wont. the combustion happens way too early and jams the starter. the reason it does this is because according to the timing light when its running fine and not popping or anything, timing is at about 30* BTC. in order to get it to crank the timing must be retarded back to about 16*, but like i said once its warmed up it will pop in the exhaust at 16*. i havent messed with this car any really and am just curious to know where to start. i know a BBC cant like that much timing, so im thinking maybe the distributor is off a tooth or something and im having to advance it way forward to make up for that. the distributor is an MSD peice and an MSD box is firing the dist. i did not install any of these parts. like i said im not sure if this is a BBC thing or not, but i thought i would ask since i have little experience with them and really wouldnt know if it was a BBC thing or not. i have checked firing order and its right. beyond that i really havent done anything other than ponder whats wrong. any ideas?
thanks
thanks
