View Full Version : 4rth gen dash in 1st gen camao build thread
RNation0001
06-19-2012, 01:03 PM
ok looks like im getting close to done on this one id like to thank everyones help on the subject for the full build thread check it out here
http://ls1tech.com/forums/forced-induction/1353147-artic-white-67-camaro-forged-ls1-iron-block-turbo-build-update-4-5-11-x-over-welded.html
https://static1.pt-content.com/images/pt/2012/06/IMG_0929-1.jpg
https://static1.pt-content.com/images/pt/2012/06/IMG_0464-1.jpg
DButler
06-19-2012, 06:44 PM
I bought a 69 from a member here that has a 4th dash that goes with it...all the brackets are fabbed...i have a gap between dash and windsheild how do you plan to fill the gap on yours and make it look good? I am to the point i need to do this before it goes to paint
CamaroAJ
06-19-2012, 06:53 PM
do you have the dash filler piece that needs about 12" cut off to fit? I've done this swap to two of my cars. it gets a lot of questions asked when at shows.
RNation0001
06-20-2012, 02:52 AM
i made mine from fiberglass but id really like to get the actual dash filler from the camaro and cut it down to fit
DButler
06-20-2012, 04:03 AM
No I don't have the filler piece. I will get one. Do you use the original gauges or do you build a bezel and use Autometer?
RNation0001
06-20-2012, 08:29 AM
well im kind of up in the air on that one i would like to use the original gauges but more than likely ill go aftermarket.
evostilo
06-20-2012, 01:08 PM
I love this mod, i did the center console but didnt have the gutts to do the dash but you guys are motivationg me!
RNation0001
06-21-2012, 04:20 AM
do it lol
RNation0001
06-21-2012, 10:03 AM
its actually pretty simple, remove windshield, cut out dash, hold new dash in plce while u drill holes, bolt to firewall then weld on two brackets in the lower sides to bolt dash to and wala its pretty secure, i may go back and weld another bracket in the center under the dash for a little added stability
RNation0001
07-02-2012, 09:00 AM
im getting some autometer american muscle series gauges
https://static1.pt-content.com/images/pt/2012/07/IMG_0957-1.jpg
https://static1.pt-content.com/images/pt/2012/07/IMG_0955-1.jpg
https://static1.pt-content.com/images/pt/2012/07/IMG_0954-1.jpg
