View Full Version : Tall Chevy spindles
Gregersen46
06-17-2012, 05:29 PM
I would like to put tall spindles on the Monte without the drop to them
Chevelle598bb
06-17-2012, 05:53 PM
I think L&H manufacture the only tall afx spindles with no drop built in.
Randy67
06-18-2012, 05:06 AM
Is this for the Monte in your avatar? The 73-77 MCs had the GM tall spindles already (same spindle on 70-81 F-body). Just checking to be sure.
Gregersen46
06-19-2012, 11:26 PM
Thanks Randy67 I never knew that. But down I want to put bigger brakes on it.
Randy67
06-20-2012, 06:00 AM
You can do the 1LE conversion, plenty of info out there about it. Quick overview is 88-92 Camaro 12" 1LE front rotors and 78-96 B-body (big GM RWD cars) front spindles which are the same height as your spindle, just have caliper mounting out farther for the bigger rotor. There are kits out there from Baer, Kore3 and others if you want even bigger brakes like C5/C6 Corvette, check with them for that.
Gregersen46
06-21-2012, 02:17 PM
Thanks you for your help
