View Full Version : Sub frame 69 camaro
69bluecoupe
06-17-2012, 12:03 AM
I want to be able to use 10in wheels and also I want r/p.is there a kit that I can bolt to my stock subframe,or will it be less trouble and cost less to go aftermarket? Thanks in advance.
Chev67
06-17-2012, 07:27 AM
Check out the Ridetech Truturn setup. It is what I am doing.
makoshark
06-17-2012, 10:14 AM
Rack and Pinion on a stock subframe can cause bumpsteer. They are not worth the effort on a stock sub. A good aftermarket steering box such as the Lee box or DSE box will give you rack an pinion feel. Add the Truturn setup, new control arms and you are up there with the aftermarket subframes.
