View Full Version : How does this act similar to a sway bar
olason
06-13-2012, 03:38 PM
I came across several photos of a technology that came from race cars is my guess.
6072260721
It acts like a sway bar in respect to opposing motion by producing an opposite force on the bell crank. Is there any torsional resistance built into the pivot point in the middle of the assembly? I know this would be great for packaging as I plan to run my shock/coilover setup in the same or similar setup.
RSX302
06-13-2012, 08:32 PM
It's exactly a sway bar. The blades can rotate changing the bar resistance. If the blade is flat to the opposing force, it will flex causing body roll. As you rotate the blade perpendicular to the opposing force, it will allow maximum sway bar strength (least amount of body roll)
We use on the race cars for cockpit adjustment. Works great.
Hope that made since?
olason
06-13-2012, 08:37 PM
So is there a roller bearing or a bearing of some sort that is on the rotation axis of the blades?
what do you mean by cockpit adjustments?
And when the blades are longitudinal with the car in these cases this setup is at its stiffest point?
RSX302
06-13-2012, 10:11 PM
You can use bearings but I believe most are bushing to minimize play and maximize strength.
Cockpit adjustable meaning the driver can adjust while driving. The bottom image for example looks like it has a lockdown bolt in the center to stop the blade from moving/twisting. If you put a rod off of the bolt straight up, hook a cable to it and run to the driver, then you put a notched lever off to the side so you can move forward or backward to pivot the blade. Works nicely during a race when the fuel load reduces and the handling of the car starts to change.
With the example of the bottom image, if the blades are flat on the same plain as the rods. They will be at the strongest setting and least likely to flex. If you twist so the blades are straight up/down, then they are at the weakest setting and will flex. Looks like they have the blades around a 45 deg angle which would be in the middle of the adjustment range. You can buy different blade thicknesses depending on your application.
neki67
06-13-2012, 11:40 PM
I can see some (adjustable) flex in the set up in the second pic but not in the first pic, correct?
Thanks for posting, I was unfamiliar with this way of controlling sway action/motion.
Motorcitydak
06-14-2012, 02:41 AM
Very interesting. That top setup looks like it allows 0 actual spring rate, just solid. That bottom one seems a little better. I would think that you could use spring steel rods instead of that blade design for the road. Change the length between the mounts or the thickness of the bar and that could change your spring rate
Also if you can get your coil overs to mount parallel to the frame, its really easy to run a sway bar off your rockers. Some of em are a little hard to spot, but they are there
https://static1.pt-content.com/images/pt/2012/06/swiftC51-1.jpg
https://static1.pt-content.com/images/pt/2012/06/Screenshot20110807at113351PM-1.png
https://static1.pt-content.com/images/pt/2012/06/figure005-1.gif
This one would be a little easier to mount to a framed car that needs more room for the engine and whatever else
http://www.mulsannescorner.com/ferrari333-5.html
exwestracer
06-14-2012, 04:04 AM
60744
Here's a look at a driver adjustable version. The actual anti-roll bar (part #5) is typically VERY stiff. As mentioned, the bar arm (blade in this case) can be rotated to create a stiffer or softer bending moment at the link mount.
The "Z" bar pictured in the "Volvo" (OP above) can also be used with rubber or various density plastic bushings to allow a small amount of roll compliance.
Motorcitydak
06-14-2012, 06:15 PM
Ray, is this something you could see on a road car? I do like that 2nd pic from the OP
RSX302
06-14-2012, 08:37 PM
Opposing force is being generated by the force of the opposing spring, right? Original question after-all was; "How does this act similar to a sway bar?".
It's hard to see the top image but it looks like under the rod pivot point is the blade to allow the chassis to roll.
RSX302
06-14-2012, 08:42 PM
Here's a view of what you can do in a road car. I would love to do this to the rear as for a street car I think would give you the most benefit.
Things ain't cheap
http://www.hrpworld.com/index.cfm?tpc=Genesis-Technologies-Adjustable-Sway-Bar-Blade-Arms&form_prod_id=1436&action=product
https://static1.pt-content.com/images/pt/2012/06/11rsr0571110352080-1.jpg
MCMLXIX
06-15-2012, 01:12 AM
Proven Wicked... designed one for the 5th Gen camaro.
https://static1.pt-content.com/images/pt/2012/06/31_Web_RRSwitchBlade_6-1.jpg
http://provenwicked.com/product_detail.php?pid=MzE=&CID=OA==&VID=
RSX302
06-15-2012, 10:10 AM
That is seriously a nice piece. $975 ouch!
SLO_Z28
06-17-2012, 05:58 PM
Seeing this today made me think of this thread:
https://static1.pt-content.com/images/pt/2012/06/139-1.jpg
Check out the in car, on the fly adjustability! :
https://static1.pt-content.com/images/pt/2012/06/141-1.jpg
You can dial in or out the rear bar mid course.
olason
06-22-2012, 07:46 PM
Looking at the sites that are listed about they seem to be mention for a sway bar. They have a long end sticking out. I was looking for the pivot being between the coilovers mounting like the original post's pictures. This is where I was thinking of going with it. Each side is separate, with the central block being machined for an axial locator and bearings. I still have to figure out how to get them to rotate without weakening the blade itself.
61151
06-22-2012, 10:23 PM
Correct me if im wrong but I believe the tension comes from the mechanism below this mounting. It was refered to as torsional rod.
Ron can you verify?
heres a better shot of a similar system.
exwestracer
06-23-2012, 04:36 AM
Ron can you verify?
Tension is generated in 2 ways. The vertical rod in the picture does twist, but only after the blade is set beyond a certain angle. In this picture, the blades are at "full stiff" (LOL) and provide more resistance than the torsion rod. At "full soft", the blades are more flexible than the rod, so they bend in roll.
Keep in mind that on these inboard formula cars, there is VERY little relative motion at the A/R bar, so everything has to be pretty stiff. Kind of like running a 1000lb spring in the middle of an A arm, vs. a 500lb coilover mounted at the ball joint. Less motion requires more rate.
