Rod
06-08-2012, 07:47 PM
if you want it PM me and I will give you a paypal account to pay to,
Rod
wilwood D-52 calipers (used for 6 months) $100 dollars for the pair and i will toss in some awesome wilwood pads with them
Piston: 2 Piston Area: 2.46 Pad Volume: 3.9 Mount Description: 7.06" Floating Mount Rotor Width: 1.04
Model number, 120-10939-RD (http://www.wilwood.com/Calipers/CaliperProd.aspx?itemno=120-10939-RD)
The D52 caliper is a direct bolt-on 2 piston replacement for the factory original single calipers on many 1968-96 GM Passenger Vehicles and Trucks. Forged billet aluminum bodies, stainless steel pistons, and competition style high-temperature seals put and end to the rust, bore pitting, and seal failures that plague the OE caliper design. D52 calipers provide low-maintenance performance and a huge weight savings with high temperature reliability for the street and track.
6046860469
Distributor, Unilite, Mechanical Advance, Chevy, Big/Small Block $50 dollars free ship
used 6 months
Model # 3748201
604626046360464
GM 8.5" 95 AG PRO DETROIT EATON Master Install Kit for Limited Slip installs new run $100.00
unused $30.00 free ship
604656046660467
Rod
6046860469
used 6 months
Model # 3748201
604626046360464
604656046660467
