BWV
06-08-2012, 05:16 PM
1967 Chevy Camaro SS 350 , FOR SALE , It has had a frame off restoration to body . This what I do for a a living, not a back yard job. It is a very solid car. To many extras to list but I will try.---- New front sheet metal ---,front fllor pans,--- fire wall & dash panels----,rad support,---- Detroit Speed Sub frame connectors, ----DSE Mini tubs & shock mount plate,--- Hotchkins Total Vehicle Suspension Kit with bilstien shocks & speed tech front A arms.--- It is lowered 5in. in front & 6in. in rear.--- 4 Wheel Wilwood disc brake kit 4 piston 13in. rotors drilled & vented.---- 17x8 in. Street Lite bilit wheels in front & 17x11in. rear .--- Kumo tires front & rear . aAll body bushings are new all bolts are new ---Bottom is sprayed with linner guard---Outside is Dupont Base/Clear Pepper Gray with Black effect met fender stripe. Paint & Body is a Pro job ----Very healthy Fresh 350 motor with all new trimings including March Performance black sport track belt & pully system --- turbo 350 trans with B&M shift kit ---B&M shifter ----MSD ign & dist. ----CCP close ratio steering box & all new steering new arms & drag links Bushings----12 Bolt rear end with Moser Street Axles---373 rear gears with detriot true track posi unit---Moser rear cover ---all new bearing total new rear. Motor & trans are color keyed to car. I also have a set of Dakota Dogital Guages & senders ---- Painless wireing harness---- all new tailamps ----in the process of smoothing bumpers--- Car Runs strong but it is not mobile yet it needs master cyl. & booster to stop. I have all the brake lines new & fuel lines. Will crank & run great. OVER $25,000 IN CAR & PARTS ALONE ---NOT INCLUDING LABOR HUNDREDS OF HOURS . 2 KIDS IN COLLAGE CANT AFFORD TO FINISH. FOR SALE FOR$26,500
