View Full Version : 12 bolt question
Ishmael
09-02-2004, 06:26 PM
Can you put 3.73's in a 3.08 12 bolt or do they have different size carriers like 10 bolts?
Scott
chicane67
09-02-2004, 09:42 PM
Yes 3.73's will fit onto a three series carrier.
There are also some other gear sets available to fit the 'three series carrier' and they include:
3.08 oe and aftermarket
3.23 oe
3.31 oe
3.42 oe and aftermarket
3.55 oe and aftermarket
3.73 oe and aftermarket
3.90 aftermarket
4.10** aftermarket
4.56** aftermarket
4.88** aftermarket
** available for use without a spacer, aka a 'thick gear set'.
Ishmael
09-03-2004, 09:06 AM
Nice! Thanks for the info. The same guy that offers the 12 bolt says he has a versaille posi 9" with disc breaks and 3.70's for the same price. Do you know if that would bolt in or would it need work. I can't believe the help I'm already getting on this site!
gmachinz
09-04-2004, 03:56 AM
Scott, you want to double-check the overall width compared to the 12-bolt since that can heavily influence your choice of wheel. Yes you can bolt it up BUT-you will need to swap spring perches/shock mounts onto the 9" and check with Spicer for a u-joint for use on the 9" pinion to your driveshaft. The only trouble area might be with the e-brake cables-that might be tough, not sure. Hope this helps a little. -Jabin
Hey, nevermind about the e-brake problem. In fact don't even use those. TSM and others offer pinion mounted e-brake kits which are SWEET! Lokar offers them, too. Later, Jabin
Ishmael
09-04-2004, 10:22 AM
Thanks for the info! That makes my decision even more difficult.
Scott
