View Full Version : BFG KDW 335/30-18s - NEW
James OLC
06-05-2012, 05:31 PM
For sale - BFG KDW Tires - 335/30-18s NEW - SOLD!!!
Tires are located in Salinas, CA
Cheers
James
James OLC
06-06-2012, 09:07 AM
Updating in response to PM's (all replied to)
These are KDW 2's
They were manufactured the 11th Week of 2012 (3rd week of March)
They are brand new and never mounted (delivered direct from BFG yesterday)
Shipping is from Salinas, CA 93908 - FedEx looks cheapest but feel free to investigate other options. If you arrange it, we can make it happen.
James OLC
06-08-2012, 07:09 AM
One pair left.
Thanks everybody!
mpozzi
07-16-2012, 06:00 PM
Yep, one pair of fresh and brand spanking new BFG KDW's (new tread design) are still left and are looking for some pavement lovin' ... $525 for the pair (buyer pays shipping if I can't deliver locally or within my work travels).
PM me or reply here if interested and thanks,
Mary Pozzi
rsk68
07-17-2012, 05:39 PM
What is the tread wear rating? I can't find a spec on these, tire rack dosnt even list this size!
rsk68
07-17-2012, 05:44 PM
Hi Mary!
I think these have a tread wear rating of 300, is this correct? If so how do they compare to the michilen pilot sports at 200 tread wear?
James OLC
07-18-2012, 06:26 AM
From the Tire Rack website (http://www.tirerack.com/tires/tires.jsp?tireMake=BFGoodrich&tireModel=g-Force+T%2FA+KDW+2):
The BFGoodrich g-Force T/A KDW-2 (KDW for Key feature: Dry and Wet traction, the "2" is our addition and identifies that this is the second generation g-Force T/A KDW) is the Ultra High Performance Summer tire that was developed to provide a blend of a dramatic-looking, ultra high performance tread design with superior dry and wet road performance. The BFGoodrich g-Force T/A KDW-2 is available in sizes for drivers of the world's hottest sports cars, coupes, sedans and light trucks. Like all summer tires, g-Force T/A KDW-2 tires are not intended to be driven in near-freezing temperatures, through snow or on ice.
The g-Force T/A KDW-2 features large tread blocks to enhance dry road stability, handling and wear under high torque loads, while rounded shoulder profiles help provide feedback for the driver by communicating the tire's progressive and predictable characteristics as they reach their limits of adhesion. A silica-reinforced tread compound with wide circumferential and lateral grooves form a directional tread design to speed water evacuation, improve wet traction and reduce the risk of hydroplaning. Internally, the twin steel belts are reinforced by BFGoodrich's ETEC (Equal TEnsion Containment) System which uses spirally wound nylon strips to provide excellent strength, consistent footprint pressure and maximum contact area under Y-speed rated conditions while it reduces weight and helps provide more uniform ride quality. The g-Force T/A KDW-2 tires feature g-Control sidewall inserts to resist deflection and generate cornering force while rim protector ribs help protect alloy wheels from curb damage.
Sizes and Specs (http://www.tirerack.com/tires/tires.jsp?tireMake=BFGoodrich&tireModel=g-Force+T%2FA+KDW+2):
335/30ZR18
Load Index 102 = 1874lbs (850kg) per tire
Speed Rating “Y” = 186mph (300kph)
102Y SLMax Load = 1,874 lbs
Max psi = 51 psi
Treadwear: 300
Traction: AA
Country of Origin "US" = UNITED STATES OF AMERICAUS
g-machine
08-14-2012, 06:42 AM
pm sent to Mary
firebirddady69
08-14-2012, 11:21 AM
how much shipped to socal 91605 ?
James OLC
08-14-2012, 01:27 PM
I will check with Mary today on availability. I think we might have one set left.
James OLC
08-16-2012, 10:34 AM
I am told that the final set is SOLD pending receipt of payment. If something changes then I will update everyone. Thanks! James and Mary
