Twentyover
06-04-2012, 02:00 PM
Guys-
I’ve rebuilt the front suspension of my 70 Camaro and have encountered a problem on reassembly. I’ve rebuilt the front using NAPA center link, idler, and inner and outer tie rod ends. The replacement inner and outer tie rod ends appear to be approximately the same length as the original inner and outers.
I have a set of aluminum toe adjustment sleeves from a major manufacturer (sponsor here.) When I tried to install them, I found they locked (I assume I ran up against a change in threadform due to tap profile) when the center to center distance between the inner and outer tie rod ends was about ½” greater that the old parts I was replacing. I had waaaaayyy too much length between the centers of the inner and outer tie rod ends to achieve anything close to correct toe. The gap between ends on the inner and outer links I’m removing from the car is about 3/16” (viewed through the gap in the split sleeve), so I’m not surprised that I can’t achieve the same center to center length with the aluminum sleeve. I assume that any aluminum sleeve, from any manufacturer (and probably most steel sleeves) would encounter the same condition.
I have a couple options-
Reuse the OEM style sleeves
Get a bottoming tap to cut the sleeve threads a little further in
or
Whack a quarter inch or so of threaded length from both the inner and outer tie rod ends and use the sleeves. This would leave maybe ¾ “ of the sleeve ‘hollow’ with no section of tie rod end, so has a small risk of column buckling.
Is there another option? Is cutting down the length of the tie rod ends a crazy suicidal idea that will result in imminent danger to the public and my probable death? Or should I break out the SAWZALL O’ DEATH and have my way with the tie rod ends? While I do think the bottoming tap will increase the depth the tie rod ends will engage, I’m not confident that even when I’ve taken each side as deep as I can that I’ll be in the range of toe adjustment I need.
I’m waiting here, baited breath, with my trigger finger trembling over the switch on the SAWZALL…….
or
