newvintageusa
06-03-2012, 05:21 AM
The New Vintage custom package for 70-72 Chevelle SS, El Camino SS and Monte Carlo SS
updates your stock cluster with new components, technology and great looks you have come to expect from NVU. Each kit is designed to have a factory installed appearance with some upscale touches.
Great features include full size factory match 0-90 fuel gauge, programmable speedometer, tachometer and discreet temperature, oil pressure and voltmeter all in the factory locations. Kits include gauges, mounting bracket to install in your factory carrier (not included), LED turn signals, temperature and pressure senders, and even a GM style speed sender. With two styles and 3 colors, choose the design that fits your vehicle. Choose the OE inspired black dial with retro styled mint green graphics, or the white or black Performance for an upgraded, performance look.
Included in each kit:
3-3/8 speedometer 140 MPH electronic
3-3/8" tachometer 8000 RPM
3-3/8" fuel gauge 0-90 ohm GM match
2" voltmeter 10-16V
2" oil pressure
2" water temperature gauge
Oil pressure sender
Temperature sender
Bushing kit
Mounting brackets
LED signal lamps
GM style speedometer sender
Gauges Bezeled without lenses, installs in factory
dash carrier, not included
16X12X6 5# MADE IN USA
70-72 CHEVELLE SS, EL CAMINO SS, MONTE CARLO SS
72601-69 70-72 CHEV SS, MONTE SS PACKAGE RETRO
75601-01 70-72 CHEV SS, MONTE SS PACKAGE PERF BLACK
75601-03 70-72 CHEV SS, MONTE SS PACKAGE PERF WHITE
https://static1.pt-content.com/images/noimg.gif (http://rides.webshots.com/photo/2330764930057582025zDcUJx)
https://static1.pt-content.com/images/noimg.gif (http://rides.webshots.com/photo/2199926580057582025QoTKox)
https://static1.pt-content.com/images/noimg.gif (http://rides.webshots.com/photo/2034461270057582025IquYYf)
2" voltmeter 10-16V
2" oil pressure
Oil pressure sender
Temperature sender
Bushing kit
Mounting brackets
LED signal lamps
