View Full Version : Large list of New Chevy V8 parts and some Used Parts For Sale
cars4one
06-02-2012, 03:33 PM
Chevy V8 Parts For Sale
https://static1.pt-content.com/images/pt/2012/06/Chevy_V8_Parts_For_Sale_c2038686402c0e9c-1.jpg (https://www.pro-touring.com/%3Ccenter%3E%3Ca%20href="http://www.use.com/Chevy_V8_Parts_For_Sale_c2038686402c0e9c99bd"%20ta rget="_blank"%3E%3Cimg%20border="0"%20src="http://media.use.com/images/s_1/Chevy_V8_Parts_For_Sale_c2038686402c0e9c99bd_1.jpg "%3E%3C/a%3E%3C/center%3E)
https://static1.pt-content.com/images/pt/2012/06/c2038686402c0e9c99bd_2jpgistruepstrueran-1.jpg (https://www.pro-touring.com/%3Ccenter%3E%3Ca%20href="http://www.use.com/Chevy_V8_Parts_For_Sale_c2038686402c0e9c99bd"%20ta rget="_blank"%3E%3Cimg%20border="0"%20src="http://media.use.com/images/s_1/Chevy_V8_Parts_For_Sale_c2038686402c0e9c99bd_2.jpg "%3E%3C/a%3E%3C/center%3E)
Edelbrock Performer #3701 Intake Manifold with EGR provision $110 SOLD
https://static1.pt-content.com/images/pt/2012/06/7318602172_4457663717_b-1.jpg (https://www.pro-touring.com/%3Cimg%20src="http://farm8.staticflickr.com/7227/7318602172_4457663717_b.jpg"%20alt="car"/%3E)
Used Rochester Quadrajet GM 4 BBL Carb $30.00
https://static1.pt-content.com/images/pt/2012/06/7318601944_830b30cc6b_b-1.jpg (http://farm8.staticflickr.com/7101/7318601944_830b30cc6b_b.jpg)
Chrome Valve Cover Breather $11.00
PAW Valve Cover Cap $6.00
TRANS-DAPT Chrome Baffled Valve Covers $30.00
https://static1.pt-content.com/images/pt/2012/06/7318602220_0b1a105fb4_b-1.jpg (http://farm8.staticflickr.com/7231/7318602220_0b1a105fb4_b.jpg)
ACCEL Blue Print Series Point Type Distributor $75.00 SOLD
MR. GASKET Distributor Shim Kit $8.00
ERSON Chrome Distributor Clamp $8.00
https://static1.pt-content.com/images/pt/2012/06/7318602300_8ab73661d2_b-1.jpg (http://farm8.staticflickr.com/7220/7318602300_8ab73661d2_b.jpg)
ELGIN Pro Stock 8- Roller Tip Rocker Arms 1.6 ratio $65.00 SOLD
ELGIN Pro Stock 8- Roller Tip Rocker Arms 1.5 ratio $55.00 SOLD
https://static1.pt-content.com/images/pt/2012/06/7318601850_b9de5d1e44_b-1.jpg
(http://farm8.staticflickr.com/7098/7318601850_b9de5d1e44_b.jpg)
TAVA Performance Product Engine Fastener Kit $36.00 SOLD
https://static1.pt-content.com/images/pt/2012/06/7318602352_8ce9a9a11d_b-1.jpg (http://farm8.staticflickr.com/7220/7318602352_8ce9a9a11d_b.jpg)
GM#12551537 Harmonic Balancer $72.00
https://static1.pt-content.com/images/pt/2012/06/7318601790_083b3449c4_b-1.jpg
(http://farm9.staticflickr.com/8022/7318601790_083b3449c4_b.jpg) GM STUDS (5) for Windage Tray $20.00
https://static1.pt-content.com/images/pt/2012/06/7318602412_e4ceaa9a84_b-1.jpg (http://farm9.staticflickr.com/8146/7318602412_e4ceaa9a84_b.jpg)
GM #Deflector (Windage Tray) -(2) $40.00
PROFORM CHROME Oil Pan Dip Stick and Tube $12.00
SUMMIT Oil Pump STUD KIT $10.00
ARP Black Oxide Oil Pump Shaft Kit $12.00
High Volume Oil Pump $38.00
ELGIN Oil Pick Up $10.00
Oil Pick Up $5.00
https://static1.pt-content.com/images/pt/2012/06/7318601738_8c551df613_b-1.jpg (http://farm8.staticflickr.com/7098/7318601738_8c551df613_b.jpg)
TRANS-DAPT CHROME Fuel Pump Plate $6.00
Milodon Fuel Pump Push Rod $8.00
Holley Street Performance Triple Chrome Plated Fuel Pump $70.00
https://static1.pt-content.com/images/pt/2012/06/7318602494_4b61160e9e_b-1.jpg (http://farm9.staticflickr.com/8167/7318602494_4b61160e9e_b.jpg)
MR. GASKET Timing Tape 6 ¾" Diam. $6.00
MR. GASKET Timing Tab $10.00
DR976 Distributor CAP $4.00
PAW Heavy Duty Starter Solenoid $11.00
MR. GASKET Wire Loom Holder Set $12.00
https://static1.pt-content.com/images/pt/2012/06/7318601684_0d3b08fc5f_b-1.jpg (http://farm9.staticflickr.com/8143/7318601684_0d3b08fc5f_b.jpg)
8227 Hose Adapter 1” NPT to 1 ¾” Hose Anodized $10.00
SPECTRE 5/8” ID Heater Hose Flex 10’ $6.00
8226 Hose Adapter 1” NPT to 1 ¼” Hose Anodized $10.00
MOROSO Hose Adapter 1” NPT to 1 ¾” Hose $14.00
MORSO Radiator Hose Filler Alum $16.00
MOROSO Hose Adapter 1” NPT to 1 ¼” Hose $14.00
HYGRADE Choke Thermostat $8.00
TRANS-DAPT O-Rings $3.00
GP O-Ring Style CHROME Water Neck Corvette Camaro 1985 up with TPI $22.00
NIEHOFF Relay $8.00
https://static1.pt-content.com/images/pt/2012/06/7318602528_d320cc02f1_b-1.jpg (http://farm8.staticflickr.com/7085/7318602528_d320cc02f1_b.jpg)
TUFF STUFF #1534 AC WATER PUMP $55.00
https://static1.pt-content.com/images/pt/2012/06/7318601626_25c543f60f_b-1.jpg (http://farm9.staticflickr.com/8002/7318601626_25c543f60f_b.jpg)
Used Oil Pan with Skid Plate $11.00
4 BBL Gasket $2.00
TORQUE PLUS Intake Manifold Gasket $12.00
FELPRO EIS 1071 PT Remanufactured Engine Gasket Set $90.00
https://static1.pt-content.com/images/pt/2012/06/7318602600_62e5b05ce2_b-1.jpg (http://farm9.staticflickr.com/8147/7318602600_62e5b05ce2_b.jpg)
Engine Builders Gasket Set, Partially Opened, Head Gasket Set (Pair) Asbestos/Steel Sandwich R-1110 $40.00
https://static1.pt-content.com/images/pt/2012/06/7318601554_6483177fb9_b-1.jpg
(http://farm8.staticflickr.com/7241/7318601554_6483177fb9_b.jpg) AUTO METER Auto Gauge Oil, Temp, Volts Gauges $55.00
MR. GASKET Ultra Seal Crank Bolt 7/16-20x2 1/4” Set $11.00
Doorman HEX Flywheel Bolts Kit $16.00
CHROME Alternator Bracket $12.00
TRANS-DAPT Hood Lock Set $30.00
DYNOMIX Gen/Alt Side Mount Bracket $16.00
PROFORM Alternator Generator Arm CHROME $15.00
CHROME Timing Cover a few dings $11.00
https://static1.pt-content.com/images/pt/2012/06/7318602652_dbb7e57676_b-1.jpg (http://farm9.staticflickr.com/8151/7318602652_dbb7e57676_b.jpg)
TRANS-DAPT Extra Heavy Duty Motor Mount Pads $23.00
DYNAMARK Coil Spring Spacer -2 $8.00
https://static1.pt-content.com/images/pt/2012/06/7318601508_da459d16c2_b-1.jpg (http://farm8.staticflickr.com/7216/7318601508_da459d16c2_b.jpg)
PROFORM Part #66904 1-Wire GM Alternator $50.00
https://static1.pt-content.com/images/pt/2012/06/7318601466_ecc7b1c665_b-1.jpg (http://farm8.staticflickr.com/7101/7318601466_ecc7b1c665_b.jpg)
Engine Bolts with strip of thread sealer $16.SOLD
Parts are located in San Diego, CA area.
All Parts Sold AS IS Where IS No Returns. Prices Does Not Include Shipping.
PayPal Accepted
[email protected]
http://www.use.com/Chevy_V8_Parts_For_Sale_c2038686402c0e9c99bd#photo =1
83C_CamAroZ28
12-14-2012, 05:12 PM
do you still have the Used Rochester Quadrajet GM 4 BBL Carb $30.00?
