BulldawgMusclecars
05-29-2012, 12:25 PM
I have a complete 1991 TPI 350, with aprox. 60K miles on it, that was pulled from a wrecked 1991 Z/28 Camaro several years ago. The engine ran great when pulled, and has been stored inside for the last 17 years or so. Engine is sold with the complete TPI setup still installed, the full underhood wiring harness with all relays, the original (730) computer, the dual electric fans, the original Camaro exhaust manifolds, and the front accessories. The driver's side accessory bracket is broken, and will need replacement, but all accessories (alternator, PS pump, AC compressor) are intact. Engine has the optional oil cooler installed. Engine is completely stock. If you have a TPI car that could use freshening, or just want a more fuel efficient engine to swap into your older car, this would be perfect. Engine can be seen at Bulldawg Musclecars, 4666 S Main Street, Acworth GA 30101, during regular business hours. Cash only. 770.975.8980
