aronhk_md
05-24-2012, 06:10 PM
Finally here...forward facing headers to fit O-port
First generation firebirds
Second generation firebirds
68-73 GTO/Lemans/Tempest (A-body)
70-73 Ventura
MAYBE 64-67 GTO etc (A-body). Problem here is we dont have a test frame for trial fitting.
They are ready to go. 1st set has been built, jigs finished to reproduce. Its a done deal. They are 1 3/4" mild steel 4 tube into forward facing collectors. 2" versions will be available later, but unless you have an IA2 block I wouldnt want them personally. My car made just under 1100 hp with tiny 1 5/8" headers and iron heads that flowed 230 cfm at .600 on the intake. That was with some awfully tight 180 degree bends before reaching the turbo on my old setup too. Too large just means a slow spool up.
An option is available to weld V-band flanges to the end of the collector (price varies on whether you want a 2.5" or 3" outlet collector...I'd recommend 2.5" for most). An option is also available for a cone to be added to each collector inside ($30 extra). I am looking into coating locally for these if you opt to have the v-band clamps added. Bungs for sensors can be added as an option too.
Essentially you will have to add your own crossover pipe and turbo/wastegate flange, but thats minor compared to the work thats been done to make these things fit. My turbo will be back on the firewall again, but most of you like it up front.....or twins of course.
Base price for headers before any options is $650, and if you order now they are in the box and on their way to you in 7-10 days. Let me tell you that these things took some WORK to get laid out properly to clear frame, steering shaft, steering gearbox and a-arms. The pics show them without collectors but the collectors ARE included.
There will be a 2nd design on the drivers side for anyone who wants it (especially 2nd gen birds with that steering gearbox forward) for the collector to extend farther forward than in the pics. That design will be complete next week. D-port version is also available by pre-order, but due to the jig modifications that need a few more days they will be 14 days from order time if ordered now. That timeframe will shorten once the 1st set is shipped.
Posting a few pics here, but more can be seen at
http://s249.photobucket.com/albums/gg223/aronhk_md/headers/
P.S. - THE SET PICTURED HAS TACK WELDS IN MOST SPOTS ONLY AS EACH ONE HAD TO BE DISASSEMBLED TO REPRODUCE EACH PIECE. THOSE ARE NOT FINISHED WELDS. IF YOU WANT EXAMPLES OF FINISHED WELDS PLEASE LOOK OVER AT PERFORMANCEYEARS.COM IN THE TECH FORUMS, IN THE EXHAUST SECTION UNDER TRIBAL TUBES TRI-Y HEADERS. LOTS OF PICS THERE.
https://static1.pt-content.com/images/pt/2012/05/1337908021-1.jpg
https://static1.pt-content.com/images/pt/2012/05/1337908028-1.jpg
https://static1.pt-content.com/images/pt/2012/05/1337908023-1.jpg
https://static1.pt-content.com/images/pt/2012/05/1337907987-1.jpg
https://static1.pt-content.com/images/pt/2012/05/1337907847-1.jpg
70-73 Ventura
