View Full Version : Where to buy rear end?
96Z28SS
07-19-2005, 03:37 PM
I want to buy a 9" or a 12" and have it shortened cause I will be doing a mini-tub on my 1969 Camaro. I want to fit a 18x12 rear rim .
Bob
rockdogz
07-19-2005, 04:32 PM
Lotsa places, Currie Enterprises (http://www.currieenterprises.com/cestore/default_rearend.aspx), Moser (http://www.moserengineering.com/) ...
I got a FAB 9 housing from Chris Alston's Chassisworks (http://www.cachassisworks.com).
Bill Howell
07-19-2005, 07:06 PM
https://www.pro-touring.com/forum/showthread.php?t=6884
Maybe this tread will help? Most companys mentioned do 12 bolts too.
chicane67
07-19-2005, 07:16 PM
In my opinion....
You dont need to shorten the housing.... unless you wanna play with the wheel offset.... which still isnt necessary, but if thats the plan....
I would recommend (in order):
Mark Williams (http://www.markwilliams.com/)
Summers Brothers 530 S. Mountain Ave. Ontario, CA 91762 800/221-7532
Strange Engineering (http://www.strangeengineering.net/)
Then maybe Moser. Currie.... CAC etc. Man, that Fab 9 is boat anchor in weight.....
rockdogz
07-19-2005, 08:22 PM
Really? I didn't think it was that heavy - although it sure looks beefy - but then I didn't have anything to compare it to except the fully loaded 10-bolt that I pulled off. Now that was heavy...
chicane67
07-19-2005, 08:45 PM
I should call Pete and have him weight the same length HD housing and compare it to the FAB 9....
That would be interesting, yes ?
