View Full Version : RnD Fabrication releases late C10 / C20 / Blazer radiators for 1973-1987 models!
SparkyRnD
05-15-2012, 08:02 AM
We just released our latest line of radiator, for the late Chevrolet and GMC C10 & C20 pickups and for the Blazers, for 1973-1987 models! These are as thick as a four core radiator (we use dual 1" thick cores, for a total core thickness of 2"), and are as wide as the big-block radiators. Note that these will work with both the top-plate style mounts as well as the individual top mounts (one at each end). These are a direct fit with no cutting or welding to the original core support. We leave a little extra material on the upper tabs so you can file down slightly if necessary to provide a very tight fit with the original rubber mounts.
The unit shown was for a customer using a mechanical fan, but we will be building all future units with the fan shroud tabs built in. They also include a trans cooler unless you request to have it built without one. These are live on our site at http://www.rndfabrication.com/C10late.html. The discounted PT member price is $455 for the radiator, and $220 for the fan & shroud kit.
These can be built for stock motors, big blocks, engine swaps and LS motors (with both inlet and outlet on the passenger side, including the steam port).
https://static1.pt-content.com/images/pt/2012/05/C10Late1-1.jpg
https://static1.pt-content.com/images/pt/2012/05/C10Late2-1.jpg
Contact us with any questions or comments.
SparkyRnD
10-02-2012, 06:30 AM
Make sure to mention that you are a pt.com member for your discount!
hag6888
11-02-2012, 09:21 PM
How about some stuff for the 67-72 C10
SparkyRnD
11-03-2012, 09:02 PM
You mean like these:
https://www.pro-touring.com/showthread.php?93230-RnD-Fabrication-1968-1972-Chevrolet-amp-GMC-early-C10-C20-Blazer-Radiators!&p=939525#post939525
hag6888
11-05-2012, 09:44 PM
Yeep that's including the fans right?
SparkyRnD
11-06-2012, 12:29 PM
Prices listed are for the radiator and then a separate price for the fans.
