View Full Version : 1970-1977 master cylinder and booster
2ndgener
05-09-2012, 02:53 PM
I have a manual brake 70 camaro with rear drums, a local guy is parting out a 77 z28, does anyone know if the master cylinder and booster will fit my 70? Also will the gear box interchange?
Apogee
05-09-2012, 04:48 PM
To the best of my knowledge, the booster is the same from 70-77, so you should be good there. As for the master cylinder, the '77 is a 1-1/8" bore disc/drum unit as well, so you should be fine there. I believe they used the same 1-1/8" bore unit from 1970-1980 IIRC.
As for the gearbox, I don't know, although it might help if you specified whether it's a manual or power steering gear. There were two ratios to choose from, maybe somebody a little more familiar with the second gens with chime in.
Tobin
KORE3
Skip Fix
05-09-2012, 05:15 PM
Gear box-depends some early ones had a coarse spline input shaft and later a 26 spline finer spline so clutch disc is different. Some Muncies had the same output shaft as a TH 350 M22 and some of the ST-10 in later ones had the same larger one as TH 400s. 77 is probably a ST-10 vs a Muncie and shifter linkage is differenet mainly the reverse linkage.
2ndgener
05-09-2012, 06:22 PM
gear box-depends some early ones had a coarse spline input shaft and later a 26 spline finer spline so clutch disc is different. Some muncies had the same output shaft as a th 350 m22 and some of the st-10 in later ones had the same larger one as th 400s. 77 is probably a st-10 vs a muncie and shifter linkage is differenet mainly the reverse linkage.
sorry for the mix up but we were talking about steering boxes, my fault, thanks tho
Randy67
05-10-2012, 05:47 AM
Tobin is right, 1970-80 booster & master cylinder interchange, only 81 is different with its aluminum master cylinder.
Steering boxes interchange as well, with 80-81 having o-ring fittings instead of flare fittings (power steering), but easy enough to work around.
Skip Fix
05-10-2012, 10:19 AM
Steering box intermediate shafts change to metric around 79 for sure 81 also so different rag joint due to splines on the box. I think my 79 used the same splines as a later IROC box so may 78 and earlier for the box. They don't sell a new rag joint for the later boxes just a repair kit from what I remember on my 81. 79 I went Borgeson U joints and shaft.
