View Full Version : Is DSE Steering Box smaller then stock?
AM.MSCL
05-08-2012, 04:48 AM
Last night driving the 69 Pontiac Firebird around for a little bit the power steering turned to manual steering.
I have not had a chance to determine if a hose, pump or steering box died but plan to look tonight.
A contributing factor to this might have happening is the fact that a header primary has 1/32 of an inch of space between it to the steering box when it does not touch. Last night the power steering reservoir was scorching hot which leads me to believe the power steering fluid finally got cooked and caused something to fail.
My questions:
Is the DSE power steering gear box physically smaller in size from the stock steering gear box?
Does any company have a steering gear box that is physically smaller in size from the stock steering gear box?
Reason I am asking is if it is smaller then I might be able to get more space between the header primary and the gear box so the heat will not get transferred into the steering box.
The Headers have been ceramic coated to help keep the heat inside the primaries.
Ray
claytonisbob
05-08-2012, 05:30 AM
Any 600 box is smaller than the stock 800 series boxes. I believe that's what DSE and Lee both use if specified. They're not cheap, but they're much better quality than any 800 box. Plus they're quite a bit lighter too.
