View Full Version : Project - "Nitpick" - 1968 Camaro
lickitysplit
05-06-2012, 10:34 AM
deleted
lickitysplit
05-06-2012, 10:36 AM
deleted
72Z/28
05-06-2012, 11:53 AM
Nice project:cool:, keep us updated with lots of pics
lickitysplit
05-06-2012, 02:13 PM
There will be lots of pictures. Movement will be a little slow at first because I don't have my workshop yet. My plan so far has me cleaning the front frame and painting it, then ordering all the suspension components so I can start rolling it around. Also, in the meantime I will be ordering and collecting parts so I have everything I need for when the build starts picking up.
lickitysplit
05-07-2012, 03:02 PM
deleted
lickitysplit
05-12-2012, 02:55 PM
deleted
BMR Sales
05-14-2012, 01:26 PM
Made some small progress today. Got the Camaro off the ground and onto some jackstands. Then began cleaning up the front frame. It was sand blasted a few years ago and only has minor surface rust.
Tomorrow I will be painting it with POR15 so that I can get it sealed so it wont rust as the rest of the build progresses. I also got my Global West solid body mounts in the mail. I will be purchasing my brothers C5 brake setup off his 69 to use on my car. Then will be getting Ridetech Coilover System and have a set of wheels in mind. My goal right now is to get the car on wheels so its easy to roll around.
Heres what we are offering a guy like you....
https://static1.pt-content.com/images/pt/2012/05/STOCK-1.jpg
Remove the upper shock with a cut off wheel or plasma, using a guide supplied use a 4" metal hole saw and drill through your frame for the coilover housing. Install the upper mount plates using a jig.....
https://static1.pt-content.com/images/pt/2012/05/MOCKEDUP-1.jpg
https://static1.pt-content.com/images/pt/2012/03/IMG_20120328_112035-1.jpg
https://static1.pt-content.com/images/pt/2012/05/IMG_20120403_173829-1.jpg
and then once the front is done we can set you up with a rear suspension too!
https://static1.pt-content.com/images/pt/2012/05/Vintage6769framedisplay-1.jpg
KHShapiro
05-17-2012, 08:03 PM
rich, that rear wont work with a mini tub will it?
BMR Sales
05-18-2012, 10:52 AM
The vast majority of our customers are mini-tubbed cars. The control arms & wheel wells usually only allow a 315 tire on a 10"-11" wheel while using the a 10 or 12 bolt rears. This limitation is due to the factory leaf spring perch locations on those rearends.
If you buy our kit with a Ford 9" housing we can locate the control arm mounts further inward & will allow up to a 345 tire on a rim up to 13" wide with widened mini tubs to accommodate them. We can build the 9" housing ranging from OE wheel offset up to 5" narrowed (2.5" per side).
