The GMR
05-03-2012, 06:10 PM
Introducing the latest offering from The GMR, a complete full floater package designed for the pro-touring market that will not only last on the track but provide serious style. Boasting an impressive Strange housing with The GMR Flair, strength is no longer a concern. We would like to remind you that this package comes standard with 14 inch GT rotors and bulletproof 35 spline Drive plates / Hy-Tuf axles. Why settle for marginal when your new Standard is 35 spline? Concerned with 35 spline being Too Heavy?… please keep in mind we are The GMR and our mantra is… “Lighter – Stronger – Faster”…
Package Includes the following:
-Strange Housing with GMR Flair (GMR Filler w/-6 vent installed)
-GMR 35 spline Full floater Hub Assembly
-Wilwood 14 inch GT rotors
-Wilwood SLR Calipers with radial mounts
-Snouts, Caliper Brackets, and GMR filler Professionally Installed!
-Strange Engineering 35 spline Hy-Tuf Axles
$4999.44
Due to variances and client preferences we did not include brake pads or Third Members in the package offering. The GMR is a direct dealer with Strange and Moser so If you would like to add these items to your package please contact The GMR for investment structure.
Professional Suspension bracket install is not only available, but strongly recommended prior to Full floater Snout Install. Please contact The GMR for investment structure for your specific setup, please keep in mind that anything is possible! If you do not want to use your suspension manufactures brackets The GMR also offers complete CAD design and Professional Install.
BONUS : With the Investment in a GMR package you will receive a complementary Master Cylinder for your overall brake package! With a $239 value these master cylinders will go fast so be sure to get your order into GMR asap!
*** 7/8 inch master cylinders only available while supplies last, no substitutions please***
Optional GMR spot Caliper Upgrade!
The GMR is proud to introduce the NEW Parking Brake Option that will complement your GMR Full Floater Hubs! After deliberation & research we have concluded that these are the absolute BEST option for your GMR setup. Although they are New to GMR, the calipers and design are NOT! These are tested and PROVEN calipers that are Manufactured by IPSCO to our specifications. Proven on the infamous ACR Dodge Viper these units are guaranteed to properly hold a 4000 pound vehicle up to a 20% grade.
These Calipers are precision machined from Aerospace Grade 6061 T-6 Aluminum and color matched Hard Anodize to your GMR Hubs. The units are completely self contained with a quick throw arm for optimal versatility. Several options for cable mounts are available and the provided bracket offers a simple “lug” style mount for ease of installation onto any rear housing. The Universal design fits just about ANY rotor on the market and custom applications are also available. Additional setup includes 2 GMR spot calipers, CNC machined backing “lug” mounts, cable bracket, cable arm, and GMR CNC weld on brackets.
Professionally TIG welded / Installed $724
$4999.44
