View Full Version : Axles fit spools and posis?
Skip Fix
05-01-2012, 02:47 PM
So I have a 12 bolt with 33 spline Moseraxles and a Moser spool, will they fit a Eaton 33 spline posi also?
Also a Ford 9" with 35 splines fit spool and Locker?
Or are the angles of the splines slightly different from spools and posis?
carguykeith
05-01-2012, 08:09 PM
The cut of the splines will be exactly the same from a posi to a spool, however axle length and possibly the spline length could be different. Best bet would be to call Moser and ask, they are probably going to want some dimensions off the spool axles then they should be able to tell you if you can run them with a truetrac.
Skip Fix
05-02-2012, 06:05 PM
Got an e mail back today saying they may work just be tight-and if too tight they could cut them deeper. Said would be tigher on an Eaton vs TruTrac.
Didn't answer the 9" Locker question.
Skip Fix
05-09-2012, 06:15 PM
35 spline 9" fit spool or Locker.
